Another thread on headlamp switch
I'm finally getting around to completing a full restore of my 1988 Porsche 911. Literally two years ago my mechanic replaced the turn signal switch on the steering wheel, and I suspect while doing that, he mis-wired the light switch. The driver's headlamp does not have low beam, and it appears that the passenger headlight is always the same intensity.
I've read many threads on the topic and have been trying to decipher electrical diagrams (I don't have the factory diagram for the 88). It also seems that the switch changed to a version 3 for 88.
I could use help on the exact color / post # applicable to the switch 911 613 029 03 (1988).
Attached are pictures of my switch and a few related that I searched for that are specific to previous versions of the switch.
Best,
tom
Old 02-14-2023, 07:06 AM
Here is the switch
Old 02-14-2023, 07:11 AM
Picture of the my 911
Old 02-14-2023, 07:14 AM
7783911's Avatar
have you installed HL relays (a must have)?
Old 02-14-2023, 01:51 PM
PCA Member since 1988
Start with the dumb stuff first. Make sure the fuses for the headlights are good. Remember, there are separate high and low beam fuses for many years (I'm not sure about your 87-89 car). Check for power at the fuses too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-14-2023, 10:34 PM
Indeed,
check both fuses first.
The you can check the wiring on your switches vs the original wiring diagram for 88 : http://911c1.de/porsche/Schaltplaene/plaene1-10_carrera_32.pdf
The light switch is in section G1/G2 with the terminals labelled and the wire colour codes indicated IN GERMAN ! (see bottom of page for legend)
1985 Carrera 3.2
Old 02-15-2023, 02:07 AM
Full Send Society
While you’re in there check the high beam switch on the turn signal lever- over time they get worn and can make contact when in the low beam setting thus always turning the high beams on.
My car suffered from that until I cleaned up and addressed the switch.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 02-15-2023, 03:41 AM
