Cevan's Avatar
Removing studs from case perimeter
I've got my engine completely disassembled. In reading and watching too many engine assembly videos, it's apparent I need the mating surfaces clean and smooth. The case parting line looks good to my eye but should I be removing the roughly 27 studs in the case half in order to run some 600 grit sandpaper along there? Wasn't sure how much of a PITA this was going to be or if there are any hazards to avoid. It appears this is the first time the case has been split. I do plan to remove the studs from the chain boxes so I can run those surfaces over a flat surface.
1986 Carrera coupe - black on black
1972 CB500/4
Old 02-14-2023, 07:12 AM
No sand paper, just draw a razor blade perpendicular to the surface with care .
You will know when it is clean .
Do this to all mating surfaces , look at the sealant thread for advice on goo and sealant .
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 02-14-2023, 07:39 AM
Takes about 20 minutes, if you have one that won’t budge try tightening a tiny bit and then loosen. If it still won’t budge use a little heat. You shouldn’t have that much difficulty. 600 grit is a little too fine just my opinion.
Old 02-14-2023, 07:44 AM
Overkill.
206 637 4071
Old 02-14-2023, 08:44 AM
Unless you are replacing those case studs with cadmium plated (bling) studs.
Tony
Old 02-14-2023, 10:36 AM
Cevan's Avatar
Ha ha, not a bling motor. Just want it to be reliable and not leak.
1972 CB500/4
Old 02-14-2023, 12:16 PM
PCA Member since 1988
If you don't have a reason to remove the studs, e.g., sealing surface gouges, then don't. You're just making extra work that can cause even more extra work. If it ain't broke, don't fix it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-14-2023, 10:20 PM
Personal preference. It's your motor and you are not a shop, so time is "cheap".
I'd pull them. But before you do, make yourself a large cardboard template and mark where each stud goes PLUS measure how much is protuding from the case surface.
With all the studs out, you can get all the sealant off nice and easily. Don't use anything silly like a flap disc etc.. only do it by hand.
Yes, removing the studs is not really necessary and it will add a lot of time, but you will find it so much easier to clean the sealing surfaces without having to navigate around a stud every couple of inches .
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-15-2023, 01:09 AM
proporsche's Avatar
no need to remove those studs at all...clean the surface with a Scotch brite and carb cleaner..gently with the razor blade....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-15-2023, 02:00 AM
