'87 Intro...and Questions
Pelicans -
I've been a long time lurker and tire kicker, but finally acquired my first air cooled car...a Diamond Blue Metallic '87 Carrera. I spent the first week getting the car detailed to my exacting specs and getting familiar with driving it. I've done a few maintenance items, including the addition of a dash lighting fuse. Next up is fluid exchanges, valve adjustment, headlight relay, etc. to get it all to a new baseline. Anyway, I have two mysteries where I need some help: 1. While installing the dash lighting fuse I found two mystery wires (see below pic). The best I can tell is that these lead back to a bundle (wrapped in very old electric tape) and head towards the ignition. 2. Headlights and Dash Lights: When I pull the headlight switch about halfway, the interior lights illuminate and I can twist the knob to adjust brightness. When I pull the knob all the way out, the interior lights go out and the headlights turn on. So...I need to get both on at the same time... I will also add that electric troubleshooting is not my forte, so I won't be offended by 3rd grade level explanations. Thanks for any insight. -Mike ![]() ![]() ![]()
PCA Member since 1988
1. Yeah, those are definitely "aftermarket." You'll just have to trace them as best you can.
2. Probably the headlight switch.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Cars and Cappuccino
Welcome. Very pretty car. Congrats. What Pete said. ^^^^^
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
I’m going to do my best contortionist impersonation today and see if I can trace those aftermarket wires back to the source.
As for the headlight switch, I have a decent understanding of how everything feeds in here. Is there a fix for this or is it just biting the bullet on a new switch? Thanks for the help.
-Mike 1987 911 Carrera Coupe 2001 911 Carrera 4 Cabriolet |
Congratulations- great looking car. Were it me, I would remove any after market wiring and get the car back to the stock wiring harness. As pointed out already, those are definitely added on by a PO.
'71 914-6 #0372 '17 Macan GTS |
aGood chance they were for a radio installation.
Did you trace it back? If so, where did it go. I imagine someone had a wiring diagram (colored) for an 87.
The red wire is still obscured by hard-to-reach electrical tape.
Pretty car! Diamond blue metallic? Looks like the 88 anniversary edition color scheme. Congrats!
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Yep, Diamond Blue Metallic over Marine Blue interior. Looks like an anniversary car but not an ‘88 and no signatures in the headrests.
Analog Air Cooled
Tell me the wire and I’ll look it up. Most of the wiring haven’t changed since 73. The 3.2 diagrams are better to trace in B&W online. The Sc and later current diagrams are better if in colour and your join all the pages up on a massive diagram.
You will quickly see what orig looks like and what’s aftermarket. Electrical is easy on these once you lean a few things. Most late 80s cars had a python or some BS immobilizer in them. For the love of all things holy rip it out. I’ve one almost burn a car down. Getting it back to stalk is always the goal 30 year later. The good news is most mods are done just bad enough that they tie into a little bit of the real wire. So you have the OG colour. The big go to’s are the main light switch and the ignition switch. Look benching ( seats out helps the neck ). The wire part ( brown ) pulls off the main unit. Look for splices into Red and yellow thicker wires. That’s normally the starting point.
86 Targa 91 964 13 6 SPD Cayenne |
