Full Send Society
Joe- PM me, I’ve got some resources for you.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
I would rather be driving
That chatGPT response is pretty funny.
Joe, I am currently using a Perfect Tuning gauge in the dash mounted in the clock hole. It is an upgrade from my earlier units. Here is an example of one I built for a clock years ago. Should be easy to find a display that fits the referenced location. I was running a serial output. That might be easier than CAN to get started. Clock replacement Programmable LCD dash gauge for EFI I have some C code to parse the data once you get the comms sorted out. Here is another one I found in the archives. I forgot about building this one. Man these were a long time ago. Megasquirt dash display
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I'll reach out to you. I read your post about a similar project. I'm intrigued, but haven't reached out because it's a bit of a priority two at the moment. I just finished up my engine and have been focused on tuning and some other things (master cylinder, brakes/rotors, a defrost project (no heat), etc...). I was interested in the project because I was waiting on engine parts and on winter "lock down" (have I mentioned I hate winter) and was looking for a stretch project.
'81 911 SC '03 BMW M3 (Sold) '64 VW Beetle, 2332, 48 IDA (Sold) Instagram: @j_smallwood |
I had found some off the shelf solutions, but I was looking for a learning project that was "cheap" and I want a really small form factor that I can blend into the dash. I wasn't interested in losing my clock - just yet, but that might be an option, if I come up short on my arduino atttempt.
Jamie - THANK YOU SO MUCH!!!!
Your historic and continued contributions to this board are incredibly helpful and valuable to me and so many others. Your posts and direct suggestions and guidance have furthered my understanding as I dig into and refine the tuning of my car. YOU DA MAN! Admins, please sticky this thread ASAP.
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
Nicely done Jamie and as usual, once again you are very generous with your knowledge!
agreed, this should be a Sticky post.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
There have been some questions related to tuning ITBs. I admit that I glossed over the Megasquirt ITB Mode above in the description. I am currently tuning a car with ITBs and was going through this process. There is a good technique using Megalog viewer to filter out data. I have used this technique for about 10 years and I just happened to find a great YouTube video that describes it much better than I can type.
I will say that this does vary depending on cam specs, ITB size, and overall engine configuration. However, the process is basically the same. I am adding this here as a reference. Enjoy! BTW, Did anyone else notice any non-linear alpha-n scaling on the TPS scale?
Looking forward to joining the fraternity... thoughts on who to trust with overhauling and repairing my 72 stacks and throttle boddies?
Guy Zindel |
Great info here, I will be using this thread to get my system running its best.
Thanks Jamie
Rutager West 1977 911S Targa Chocolate Brown |
D. |
![]() It's a Zada Tech Display that I designed a 3D printed bezel for. ![]() It works beautifully for dual AFR. I have been working more with Zada Tech and could likely get whatever you wanted in the same form factor that could display dual readouts of anything you wanted. It can also be designed to rotate through many more outputs with a small joystick (dial).
I will check with the Zada people and see what they have, sounds like there is a good solution over there. I would prefer a CANBUS connection as I already have an output run from my Motec, but an alternative might be to just tap into the O2 sensors in parallel with their connection to the Motec...I assume they just sense voltage so ought to be able to feed both the Zada and then Motec without issue. May have to research that point for a bit. Thanks so much, D. Last edited by Cloggie; 09-12-2023 at 03:46 AM.. |
Amazing work here by all involved , great help for us newbies with ITB setups.. Thank you !!!!!!!!!
Zada Tech gauges can accept CAN bus inputs also. From the CAN bus you can display any variable that the ECU can output.
New-ish 911SC Targa Owner
Not downplaying the efforts of that display, its very nicely done! But a lot of these ECMs have a CANBus network that sends all sensor data and calculated outputs thru a couple of wires. A steep learning curve but find a display or gauge that works with your ecm's CANBus and you can keep tabs on every single little thing your car is doing.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Who have you guys used to rebuild the original itb's?
Guy Zindel |
