Ubi bene ibi patria
Problem identifying this part in the PET
Hello to All & Happy (Belated) Presidents Day to our American brothers & sisters
Could someone please provide me with a p/n for this part from the front fender(s) - L & R headlight harnesses for a 1970 911T. I require only the replacement gasket or its ident. number or part description (both sides) for this portion of the harness assembly. Headlight harness - general arrangement Unknown name for, and/or P/N mystery piece & its required gasket. Any help is most appreciated. I'll post this in the 911S registry also. Thanks & Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
Diss Member
Sorry. PET only lists the left and right as "harness for headlamp".
- Left: 911.612.024.00 - Right: 901.612.047.00
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
You can always measure the gasket and replace it with general rubber weather stripping of similar size. Cut to length and superglue it into a circle.
1982 911SC |
Large o rings or some old vacuum cleaner belts, along with replacement belts for rock tumblers make good gaskets. Also McMaster Carr has solutions.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Ubi bene ibi patria
So far, it appears the best & perhaps the only option is to fabricate a gasket from some suitable material. Thanks for your input guys - much appreciated.
Cheers JB
