Turning engine for valve adjustment
1. With the spark plugs in even with all the shims out can not get the engine to turn, it will start to move a little then the belt will slip even though it is really tight. Is this a sign im going to have to remove all the plugs to do it. I read folks do it with the plugs in.
2. Also when facing the alternator/cooling fan we turn in clockwise direction. Many people mention when facing fron of engine etc, but wanted to check that when facing the fan its clockwise.
Old 02-25-2023, 10:15 AM
Cold engine, engine in Neutral, Remove spark plugs, belt/pulley tight to avoid belt slippage, only turn Clockwise….facing the engine fan.
Old 02-25-2023, 11:17 AM
proporsche's Avatar
well? do not remove the spark plugs.there is a possibility that some carbon build up could fall inside preventing the valves to close completely.That would give you false reading-adjustment
Are you sure you have no gear in ??
report..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-25-2023, 11:27 AM
r_towle's Avatar
Old trick was to put car in 5th gear and leave one wheel on the ground, or bolt a rod to it that hits the ground at an angle to hold the wheel locked.
Turn other wheel backwards, this turns engine….a lot easier, and can be done from under car.
Rich
Old 02-25-2023, 11:45 AM
Navin Johnson
TimT's Avatar
Remote starter switch
'69 911 GT-5
'75 914 GT-3
and others
Old 02-25-2023, 11:59 AM
While you turn the nut clockwise, apply pressure on the outside of the belt on the drivers side to keep it from slipping. Very important is to make sure none of your fingers end up on the inside of the belt where the turning of the pulley can get them between the pulley and the belt- yeah, imagine losing fingers that way!
Squeezing both sides of the belt together, again only on the outside also works.
Rutager West
Old 02-25-2023, 12:27 PM
This !!!!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-25-2023, 12:35 PM
Squeeze the belt with your hands.
Or, use one of these: https://www.amazon.com/GearWrench-3680-Ratcheting-Wrench-Serpentine/dp/B0002WSFTO
The serpentine belt wrench kit is perfect for turning the crank pulley instead of the alternator shaft. I prefer this method. It's very easy.
Old 02-25-2023, 01:28 PM
Not sure what crank pulley you have, but on most just put a 19mm wrench on the crank bolt and turn it over. Why mess with the fan pulley at all?
Old 02-25-2023, 03:14 PM
Bill Douglas's Avatar
That's all I've ever done. Works well.
Old 02-25-2023, 05:44 PM
Some dumbo left the car in gear. hmmm. Engine turns now I can do the valves.
I have a cabrio engine in my car. Its tight to get a wrench down there.
Old 02-25-2023, 06:47 PM
proporsche's Avatar
Old 02-25-2023, 10:01 PM
Cairo94507's Avatar
I just turn the wheel slowly while in 4th or 5th gear on my 914-6. My engine faces the opposite direction so easier than trying to use a wrench on the fan belt bolt.
'71 914-6 #0372
'17 Macan GTS
Old 02-26-2023, 05:56 AM
The same dumbo did that to me too once...
Old 02-26-2023, 06:14 AM
shoooo32's Avatar
My go-to for a valve adjustment tool is the extended length ratcheting wrench. This assumes you don't have or have already ditched the multi-belt crank pulley.
https://www.homedepot.com/p/GEARWRENCH-GearBox-XL-12-Point-Metric-Double-Box-End-Ratcheting-Wrench-19-mm-85919/313435669?source=shoppingads&locale=en-US&srsltid=Ad5pg_F4_QyI6nLo-pLdGvWs9VrB78DyN01aDrh3AEqk43fdW1b3tXu9YMc
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 02-26-2023, 06:45 AM
