I appreciate your youtube videos. Just a thought on this. I remember with one of my 912’s I noticed a difference which equaled a half an inch from side to side when I loosed the engine mounts and the trans mounts, jiggled the eng/trans assembly then tightened everything back up. I couldnt figure out why so I adjusted everything till it was equal on both sides.
Old 02-27-2023, 01:03 PM
I know porsche would paint the fender lips with a kind of a raised, dimpled, rough texture. Might check yours to see if they are all the same.
Old 02-27-2023, 04:43 PM
kav kav is offline
New User
That's interesting. I wonder if the engine and trans are centered in the engine bay. Will measure thanks!
Old 02-27-2023, 04:55 PM
kav kav is offline
New User
Yes I stripped and re-did all the undercoat / stone guard on the rear of the car.
Old 02-27-2023, 04:57 PM
Originally Posted by kav View Post
So you're the lucky one! Good to know thanks!
Ha! A lot of other asymmetries (like the depth of the torsion bushing hole for one - 5mm diff side to side! ), but maybe this tells you to start the investigation on the 10" side. Good luck and let us know what you find.
Old 02-27-2023, 05:56 PM
kgieg's Avatar
My 74 is off also. I would say past body damage, they are old cars that were not always cherished.
A fair exchange is no robbery.
Old 07-18-2024, 06:48 AM
gwmac's Avatar
My 74 is similarly off
Old 07-18-2024, 10:47 AM
Still here
pmax's Avatar
I understand the fenders measured off but do those tires look different or it's an optical illusion ?
Old 07-18-2024, 09:11 PM
MBAtarga's Avatar
I'll go with illusion. The perspective angle is different in the shots. Picture on the left is at a higher angle looking down so that makes the curvature of the tire greater.
Mark
'83 SC Targa - since 5/5/2001
Old 07-19-2024, 11:18 AM
