kav kav is offline
New User
Rear wheels are not the same offset from fender? 5/8"! Really?!
I've been rebuilding / restoring / refreshing / upgrading the suspension and steering on the Canary (My 1969 Porsche 911T) and while doing the DYI alignment I noticed the right rear wheel was poking out much further than the left. I couldn't seem to get my head around it as it was a significant amount. I tried everything, measuring with plumb lines over the fenders, pulling and poking trying to get the gap to the wheel hubs to be the same each side. I even pulled the whole rear suspension out again and started from scratch but kept getting the same result.
Right:
Left:
I went ahead and did my DYI alignment which is a pain in the ass, two full days of frustration but seemed to turn out ok. Before going out for a drive I took the rear wheels off and did a bolt check. I thought let's run a plumb line from the inner structure to the trailing arm and measure each side, maybe something's bent but it was the same side to side.
Right:
Left:
I then measured from the inner structure to the center of the rear fenders and found the problem. The left rear fender sticks out 5/8" more than the right! That's huge! Is that normal? The car has never been in an accident of any kind. I imagine there are some differences side to side in these older cars but really, over 1/2"!
Right:
Left:
Thoughts?
Cheers,
-Kav.
Old 02-26-2023, 06:04 PM
Sorry I can't help more, but my 72 is off by about the same amount as well.
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 02-26-2023, 06:10 PM
The joys of hand-built cars...
My '75 has a ~0.25" difference between the left and right fender extensions. (Right sticks out further, opposite of yours...).
Beautiful shade of yellow, and I bet that rides nice with the Koni's.
Old 02-26-2023, 07:11 PM
My F bodies are not equal
Old 02-26-2023, 07:35 PM
shinrai's Avatar
Mine G body car is out about the same. Turns out the ass end took a bump. Open the lid and measure diagonally from corner to corner to make sure it's square. If it's not square you can pull it back to where it needs to be. If it is square blame it on the drunk who put it together at the factory. Then add a 1/2 spacer to one side - which I have seen before.
'87 911 GP White "casper"
'79 930 Copper Brown Metallic "beast"
'93 968 Amazon Green Met "moby"
'97 Esprit V8 "flat eric"
'97 993 Speed Yellow "tbd"
Old 02-26-2023, 08:01 PM
I noticed the same thing on my 993. Turns the car has been in an accident, hit in left rear quarter. A new fender was welded on but had to be distorted to fit and bulged out about an inch farther then the right side. Hidden frame damage when I looked deep in my case.
Old 02-26-2023, 08:41 PM
It's a 914 ...
stownsen914's Avatar
5/8" is a lot, but I can't say I'm shocked. It may well have even come from the factory that way.
One option if the visual is bothering you, put a 1/4" spacer on the left side to sorta split the difference and reduce the visual effect. Not ideal from a suspension balance standpoint, but honestly a 1/4" wouldn't make a noticeable difference.
Old 02-27-2023, 04:56 AM
Senior Member
Kav - could be the angle or lighting, but to me the lip looks different side to side. Left side looks more rounded, the Right more squared off. Any chance that there was some body work in the past?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 02-27-2023, 05:21 AM
Full Send Society
Pull the right side out, push the left side in…
It’s metal, it’ll bend and flex 1/4” easily and then you’ll be pretty close to symmetrical.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 02-27-2023, 06:54 AM
Kav.
Just checked my 69T that has original panels. Exactly 10.5" on both sides.
C
Old 02-27-2023, 07:04 AM
Senior Member
Agree with Showdown, a little persuasion may address this to an acceptable level.
Chris
Old 02-27-2023, 07:14 AM
I had the same problem on my 1st '70T and attributed it to being hand built at the factory.
Old 02-27-2023, 09:06 AM
I don’t believe Porsche would let cars leave the factory with such an obvious flaw as that. Somethings not right when you have a 5/8 difference I would do some more investigating. Some of you might be surprised at the number of accident cars being passed off as mint or damage free. Only way to know is if you bought it off the showroom floor new or did a bare metal respray.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 02-27-2023, 10:24 AM
My 1987 was off the same way. I don't remember the differences on each side. It was a low mileage no accident car.
Old 02-27-2023, 12:39 PM
kav kav is offline
New User
Good to know thanks!
Old 02-27-2023, 12:52 PM
kav kav is offline
New User
Will double triple check for squareness thanks, I'll have what he's having!
Old 02-27-2023, 12:54 PM
kav kav is offline
New User
Will adding more spacers to one side throw off my geometry?
Old 02-27-2023, 12:56 PM
kav kav is offline
New User
Originally Posted by thetorch View Post
Kav.
C
So you're the lucky one! Good to know thanks!
kav kav is offline
New User
Sounds like it should be 10.5" each side, I will look into some persuasion. Not sure the best way to go about that?
Old 02-27-2023, 12:58 PM
kav kav is offline
New User
I will look through the records again but never seen a bill for any accident repairs. I'm pretty confident no accidents but will measure for square.
Old 02-27-2023, 01:01 PM
