Simple on/off toggle that replaces headlight washer switch?
I am looking for a simple on/off two-position switch that fits in place of the headlight washer switch. Possibly something from a 964? I thought I found it with part #964-613-325-01-01C-OEM from our host but, this is also a temporary switch like the oe washer.
Been here a while
There’s a rear wiper switch that will work.
I took apart my washer switch and removed the spring. This way it looks stock but functions as a toggle.
looking for 1972 911t motor XR584, S/N 6121622 |
Are you trying to use it as a kill switch? I wouldnt want the headlight washer running in just on off mode. That pump / wiring draws a lot of power.
Full Send Society
Get over to mouser.com or digikey.com and lose your mind over the thousands of options. You’re certain to find what you’re in search of and without any Porsche tax.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
i suggest a 3 prong so its lit at night?
The power window selector switch appears to be the same size/style. I repurposed mine as a oil cooler fan switch.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
It is a large pump, and moves a lot of water and will hose down the entire vehicle.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
