Ubi bene ibi patria
Hawkeye's-911T's Avatar
CV Boot Clamp Question
I was wondering if any of you gents have used a set of "modified-to-suit" end cutters or something similar to set or tighten the boot clamps. It seems to me to be a bit of a waste to spend $80+(US) dollars for basically a 'one-time' use tool added to the fact I am spending our 73 cent 'Canuck Buck' coupled with an unreasonable crap-load of attendant "gubmint" charges and taxes to have it shipped here.
This is one the new boots with an 'Oetiker' clamping ring.
Here's a photo of the old style clamping ring which I feel may lend itself to my "Macgyver" approach. They are in pretty decent condition & appear to be re-useable. I'm sure it has been mentioned somewhere - but after spending a ton of time going over numerous posts on the subject - I gave up looking.
Any advice will be appreciated.
Thanks & Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 03-06-2023, 04:02 PM
When a zip tie won’t do…There’s this generic brand on Amazon if available on the .CA site…
Old 03-06-2023, 04:20 PM
Racer
winders's Avatar
This tool:
https://www.amazon.com/ABN-Ear-Type-Crimping-Mercedes-Vehicles/dp/B00K0TOYJE/ref=sr_1_50?keywords=oetiker+clamp+tool&qid=1678154708&sprefix=oet%2Caps%2C198&sr=8-50
$14.99
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 03-06-2023, 06:05 PM
I have tried side-cutters in the distant past and they just don't get the clamp tight enough. I bought an inexpensive pair of clamp pliers at a parts store and they work perfectly. Those shown on Amazon would do the trick.
Another thought: Maybe your local FLAPS loans tools and has a set...
Old 03-07-2023, 10:57 PM
I used this tool successfully when I replaced CVs on my SC. It works.
Old 03-08-2023, 06:59 AM
Red Line Service
Marc Bixen's Avatar
Or, you can waste your money on this! Why do people over-engineer?
https://www.***************/pn/HZ-1847
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 03-08-2023, 12:44 PM
Walt Fricke's Avatar
I've had some success with a tile nipper I happened to have, though it was inexpensive when I bought it for its intended purpose. The cutting edges of the jaws are parallel, unlike a dyke or other side cutter.
Old 03-08-2023, 08:12 PM
proporsche's Avatar
very basic and work very well are this horseshoe pliers...the Italien USAG i bought back in 1985,and the West Germany i have found in the farm field in France..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-09-2023, 10:26 AM
Use the right tool for the job; the one that Winders posted for Oetiker Keystone clamps. They work great and are cheap.
Old 03-09-2023, 11:45 AM
proporsche's Avatar
have you noticed that the ends look identical as the horseshoe pliers?;-)
ivan
Old 03-09-2023, 11:54 AM
And tile nippers. However, the bespoke tools have blunter ends, don't they? In the grand scheme of things, the cost of that Amazon tool is chump change.
Given that some of us have had zero issues using common zip ties for this application, I think you can hardly go wrong with what you fasten these boots with.
I believe the virtue of Oetiker type clamps is that they exert a sort of spring force on what is clamped. Over time, clamped tubes of elastic material (like thickish rubber for oil or water cooling) benefit from this type of clamp. With a screw hose clamp (or a zip tie), as the tube extrudes some under the local pressure (i.e., thins out) of the clamp, the force holding it in place is decreased. With an Oetiker, that force remains constant (or decreases less). Clamps on the large elastic tubes used on turbos incorporate a compression spring which is compressed by the bolt which squeezes things together, maintaining a constant pressure despite material squishing out.
This application doesn't seem so critical, especially if you take the time to insert a tube into where the boot and the axle join, so you don't have air pressure trying to push the boot off.
Old 03-09-2023, 01:35 PM
Ubi bene ibi patria
Thanks Guys for your responses. After seeing Walt's remark re tile nipper, I dug out an old set I used for a bathroom reno from about 15 years ago. They look to be the answer as they worked perfectly on a test try with an old style clamping ring. The jaws are of a size just about the right width to be an effective tool for use on the new style.
Thanks again fellas
Cheers
JB
Old 03-09-2023, 01:39 PM
Racer
winders's Avatar
You want a tool that keeps a flat on top of the area that is squeezed. That shape helps maintain the clamping affect.
Scott Winders
PCA GT3 #3
Old 03-09-2023, 02:07 PM
proporsche's Avatar
if i do not have the original booth clamp i use these, it is stainless steel tie wrap with special pliers to use on them..
Old 03-09-2023, 03:15 PM
ivan
Absolutely not. The correct tool keeps the center part square to the clamp. Once you've used the real tool, you'd never use anything else.
Here's a "seasoned" pair for $10.
https://www.ebay.com/itm/144730120983
Old 03-09-2023, 07:07 PM
proporsche's Avatar
well..i have been using my tools for over 39 years(back those day was not Amazon) never ever i had problem .....trick of the trade, you call it;-)
Ivan
Old 03-09-2023, 11:42 PM
proporsche's Avatar
besides the tool being used.The cv joint should be serviced ,let`s say on major service.
I have made myself this tool.
Ivan
Old 03-09-2023, 11:55 PM
