Removing 02 sensor
No one talks about it but can you use PB Blaster to spray at base of old sensor to help loosen and remove? That stuff is amazing ! Thanks, Nick.
Old 03-07-2023, 07:24 PM
PCA Member since 1988
Whatever it takes. Those suckers can get seized pretty hard.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-07-2023, 11:05 PM
Spraying anything that contains silicone on an oxygen sensor will contaminate it. Check the ingredient list.
Same thing goes for dousing down the pipe to get some on the threads without cleaning everything up before screwing in the new sensor. The sensor actually compares oxygen in the exhaust to that in the air outside around the sensor, so the silicone can contaminate your new sensor rather quickly.
The usual method to eliminate seizing is to use the high temp anti-seize. But yes, sometimes they get stuck in place. Use a high quality crow foot socket made for oxygen sensors.
Old 03-08-2023, 09:16 AM
proporsche's Avatar
you cannot spray on the threads or the sensor itself ,it is inside the cat or pipe;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-08-2023, 10:01 AM
proporsche's Avatar
drive it a little and when hot warm remove it
Ivan
Old 03-08-2023, 10:02 AM
Mark Salvetti's Avatar
I got a tough one out recently by heating the bung with a MAPP torch, use an open-end wrench on the sensor body, and then try to unscrew it by tapping on the wrench with a hammer.
1979 911SC Targa
Old 03-08-2023, 06:27 PM
