-   -   pass side window not working (http://forums.pelicanparts.com/porsche-911-technical-forum/1136252-pass-side-window-not-working.html)
jgurnari 03-08-2023 06:36 PM
yesterday the pass window went up and down today it does not!
driver side works fine.
obviously not the fuse.. or driver side would not work. i tried to jiggle driver side switch for pass window and pass side switch… jiggling had worked in the past, ultimately I replaced switch on pass side.
again when i parker the car yesterday everything worked, today not!
88911coupe 03-09-2023 07:27 AM
I had a similar problem and wasted a bunch of time replacing the switches since they are notoriously unreliable. I finally figured out that the passenger side wire that goes from the body into the door had a kink in it and would randomly lose connection.
Dpmulvan 03-09-2023 07:29 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/670761-power-window-switch-relay-help.html
EC900 03-09-2023 11:47 AM
Had same problem with the Ford150 passenger window, turned out a well-hidden $5 relay was the culprit and testing it confirmed.
jgurnari 03-10-2023 10:05 AM
solved! loose wire in the door. mirror tilt should be that simple!!
