pass side window not working
yesterday the pass window went up and down today it does not!
driver side works fine.
obviously not the fuse.. or driver side would not work. i tried to jiggle driver side switch for pass window and pass side switch… jiggling had worked in the past, ultimately I replaced switch on pass side.
again when i parker the car yesterday everything worked, today not!
Old 03-08-2023, 06:36 PM
I had a similar problem and wasted a bunch of time replacing the switches since they are notoriously unreliable. I finally figured out that the passenger side wire that goes from the body into the door had a kink in it and would randomly lose connection.
Old 03-09-2023, 07:27 AM
power window switch or relay help
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-09-2023, 07:29 AM
Had same problem with the Ford150 passenger window, turned out a well-hidden $5 relay was the culprit and testing it confirmed.
Old 03-09-2023, 11:47 AM
solved! loose wire in the door. mirror tilt should be that simple!!
Old 03-10-2023, 10:05 AM
Tags
window motor , window switch
