SEM Color Coat - carpets
I have black carpets in my SC that have faded a little. I wanted to find out if anyone had experience with SEM Color Coat on carpets. I’d rather not pull carpet up to do the whole dye/rinse process. This is for a track car and not for show quality. Just breathing a little fresh life into my horse.
Old 03-15-2023, 07:03 AM
I’ve used SEM on carpet and works great. You’ll probably need more coats than you think to get the coverage and the carpet will be a lil stiff at first but should freshen it up just fine.
Old 03-15-2023, 10:34 AM
berndtj's Avatar
Here's a recent thread which includes SEM: https://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc-5.html#post11921453
Old 03-15-2023, 10:40 AM
Thank you both. Zen- how did you prep the carpets? Just vac and spray or did you go more in depth?
Will
Old 03-15-2023, 11:20 AM
Will
Hey Will,
Vac and spray is pretty much all I’ve ever done on carpet. Leather/vinyl is a different story lol.
Be sure to mask off areas for overspray, I use a cardboard shield for larger areas, and your good to go.
Old 03-15-2023, 11:56 AM
Hey Will,
Perfect. Thanks for the insights.
Old 03-15-2023, 05:07 PM
The quoted thread was mine. I used a dedicated carpet cleaner vacuum that sprays a hot cleaning fluid which I massaged into the carpet, then run the vacuum along. Cleans it up great.
I found I didn't have to do many passes to get the colour back but mine is redish, maybe black takes more. It's a bit stiff at first but if you work it with your hand it loosens up quite a bit.
Highly recommended!
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 03-16-2023, 03:16 PM
It worked great! Thanks again.
Old 03-18-2023, 02:15 PM
