Dumb question: Removing a crank sensor plug
At the engine side of my crank position sensor wire, I cannot remove the plug from the the vertical anodized bracket. Is there something that I need to do to get it out of that bracket. Thanks -Tom
http://forums.pelicanparts.com/uploa...1680368249.jpg http://forums.pelicanparts.com/uploa...1680368249.jpg |
you have to remove-slide out the security 3 point bracket.Sometimes it is also secure in place with mini phillips screw
Ivan |
| All times are GMT -8. The time now is 02:03 PM. |
