tquaglino's Avatar
Dumb question: Removing a crank sensor plug
At the engine side of my crank position sensor wire, I cannot remove the plug from the the vertical anodized bracket. Is there something that I need to do to get it out of that bracket. Thanks -Tom
Old 04-01-2023, 10:03 AM
proporsche's Avatar
you have to remove-slide out the security 3 point bracket.Sometimes it is also secure in place with mini phillips screw
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-01-2023, 12:54 PM
proporsche's Avatar
here
Which body wire is for the Crank speed sensor?
Old 04-01-2023, 12:56 PM
