Torque specs / loctite for 3.2 studs and AC bracket hardware RH side
Hi-
Upon removing motor to do fuel lines/tunnel as well as a ton of while it’s out projects one of these studs had broken. I’ve extracted and removed the other to completely replace along with all new nuts/hardware for the triangular piece of aluminum here that anchors in the main compressor mounting.
I can’t however find torque specs nor do I know whether I use loctite or similar on the studs going into the block.
If anyone could share some tips I’d be most appreciative! First time for me here.
Enjoy the weekend Pelican friends!
Old 04-02-2023, 10:00 AM
From the Bentley manual. I couldn't find anything regarding the studs into the head (camshaft case).
Old 04-02-2023, 11:46 AM
Senior Member
M8’s 25nm, M6’s 10nm.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-02-2023, 01:59 PM
I would use a touch of blue loctite and set them to the proper height, not based on torque specs. You can check to make sure you don't exceed the torque spec if you are worried about that. Do not bury the unthreaded portion of the studs with force!
The depth is given in the PET. So for example an 8 x 35 stud is an M8 with the exposed side showing 35mm above the case ... I believe. Someone can correct me if I am mistaken with the spec here.
Here is a thread on this subject.
911 Engine Case Stud Studs - Install Torque
Old 04-02-2023, 03:54 PM
Thanks so much!
Old 04-02-2023, 06:54 PM
Cevan's Avatar
On my ‘86 they measure 24.6 mm.
1986 Carrera coupe - black on black
1972 CB500/4
Old 04-03-2023, 05:08 AM
You don't need to tighten the studs very tight at all. They will hold just fine if they just sit in place with enough depth. I would just insert the studs until they bottom out and stop.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-03-2023, 07:48 AM
Thank you!
Old 04-04-2023, 08:24 PM
