Ubi bene ibi patria
Front Trunk Related Parts
Hi Guys
No luck with the PET or any other after-market supplier diagrams etc. Does anyone know of a Porsche part # for the grommets & a source for the bulkhead style ring-type(?) seals from the trunk to dash interior for the (fog, ciggy lighter & rear window de-fogger) switches? ![]() "Old" pre-resto interior Dash view ![]() Trunk side View showing seals parts in question - the grommet for the rear de-fogger disintegrated completely - the one on the left is basically useless - the one on the right might be re-usable(??) ![]() Top view through speaker opening showing location of the 3 bulkhead style seals in question. I also need some advice or recommendation on what covers or blocks the rather big hole accessing the steering gear. ![]() Any help or advice will be appreciated Thanks & Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
I’m sure you can find a standard pass-thru grommets at the auto parts store.
As for the opening in the steering column, there wasn’t any. Someone posted the same query a few months while back. My reply was that my ‘77 with dealer installed AC, the kits they used had supplied a generic foam sponge block to wrap around the shaft/tub to seal this opening, probably to help keep dust and debris from the evaporator to a minimum. Tucking any sort of similar material like that of rubber pipe wrap might do the trick, it’s just hard to seal completely. |
I think the grommets might be 999 703 066 50 and 999 703 067 50 (from 810-10 in the parts catalog): http://www.***********.com/porsche-parts/hardparts.php?dir=911-65-69§ion=801-10
but maybe someone else knows for sure? |
Ubi bene ibi patria
Hey Lz7w - Thanks for the part #'s - I'll chase those down
Cheers JB
JB,
Part numbers on your EarlyS post
Classic 1969 911T |
