lv2race's Avatar
CV Joint Leak
All - I run a 2-liter 911 with the SVRA, and last race I changed my CV Joint configuration. In the past I’ve run with 6-bolts, no cover, no gasket, and also with 4- bolts, 2-pins with a cover, no gasket. No problems with these.
I recently sourced from Porsche, a set with 4-bolts, 2-pins, no cover with gaskets. I ended leaking a lot of CV grease out through the center of the pins onto my inner wheel hubs and brake caliper, as well as all over the starter. Leaking through the pins, inboard and outboard, both sides. Is this just a case of sloppy assembly on my part? Photos attached.
Old 04-13-2023, 12:43 PM
You've got to fill the two extra holes with an epoxy.
Old 04-13-2023, 01:05 PM
lv2race's Avatar
Thanks - makes sense.
Old 04-13-2023, 05:49 PM
PCA Member since 1988
I'd try some silicone sealer first, before going to epoxy.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-13-2023, 06:14 PM
I covered the spare holes on the boot collar with heavy foil tape from the inside before installing, no issues.
Old 04-14-2023, 05:38 AM
I think it also possible that synthetic cv joint grease could stop this as it runs less.
Old 04-14-2023, 06:46 AM
It's a 914 ...
stownsen914's Avatar
Same thing on my 914 racecar. I always clean the pin holes well and put a plug of silicone/RTV in there, seems to work fine.
Old 04-14-2023, 04:25 PM
