Administrator
Rebuilding Axles in Los Angeles
I have four axles with slits in the boots, all promptly removed.
Does anyone know of a Los Angeles outfit that re-packs GKN Loebro axles?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
It's a messy job, but any indy shop working on 911s should be able to service halfshafts. Our host sells the kits. If you don't mind burning through three rolls of paper towels and smelling like grease for a week, you can do them yourself with nothing more than a snap-ring pliers.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
Racer
With your garage you should be able to rebuild them yourself.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I have used these guys for a bunch of stuff....air pumps, starters, alternators and axles
B-Z Rebuilders 7745 Alabama Ave. Unit #2 Canoga Park, CA 91304 818-703-9228 https://bzrebuilders.com/
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Not a hard job but messy as all get out as Shoooo points out above.
Your buddy Tyson?
If you do it yourself, get a fresh box of nitrile gloves. You will need it.
Also, I recommend using Redline CV2 grease. The new GKN Loebro axles I bought had such thin grease it made a huge mess under my car because it liquified and was spun all over everything: wheels, trailing arms, heat exchangers, starter, transmission, brake cables, heater boxes, underbody, rear shocks. Total, freaking mess. I had to repack them, even though they were new. Zero problems with Redline CV2. |
I did this myself many years ago...I think I'm still finding that grease on me and all over the garage. I don't know how it got so messy.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Eng-o-neer
You'll laugh, but those Flexx Boots work well...Cut the old sucker off, slide the new sucker on:
https://www.youtube.com/watch?v=spNIteA0LPQ&t=300s&ab_channel=RaidenMotors |
Yes, a mess. I found dipping in kerosine overnight to help. Then take the CV's apart and spray off with brake cleaner. Reassemble and push grease in until you get sick of doing it. Push on the boots, clamp and Done.
Sold: 1989 3.2 coupe, 112k miles |
Driver
I'm no ace mechanic, but with the aid of slodave I replaced the CV joints on my car at home. I think the hardest part was getting the axles off and back on. But you've got that scissors lift, which is nicer/higher than squeezing under a car on jackstands.
I bought the rebuild kit sold here on Pelican, and like others have noted I went through half a box of gloves and a roll or two of paper towels. I also spread a lotta newspaper all over my work surfaces to make cleaning up easier. Took an afternoon to get it done.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
1979 911 SC
It was one of the first project I ever did on my 911. I found it pretty rewarding and not terribly difficult. Yeah, it can get a little messy but that's half the fun!
Administrator
Thanks. I know I could do it. But I've got five of the axles sitting here, and I wonder if a generic axle shop could do that kind of quantity more efficiently than me.
Since I've been replacing the axles about every 2 years, I've gotten very fast at that job. The torque specs are committed to memory.
I checked my CV joints before this past track season and am curious how long they generally last. |
Administrator
Or the boots are now made of lousy Chinese rubber? But I don't see it as a common problem on the board, so I've assumed it's something about my setup.
RETIRED
I sent mine on exchange to Eric at PMB Performance. I had one set rebuilt with new boots and fresh grease by the late Kaptain Krusty in Santa Maria CA. They lasted a very short time.
He gave me a fair price for my cores and in exchange I got new CVs on fresh axles and new boots. Kwik swap and been good for ten years now.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Eng-o-neer
This isn't particularly scientific, but the Flexx Boot feels more...flexible than the OEM boot. Perhaps it would last longer in your high-angle setup.
I guess it depends on whether it's being cut by the clamp or stretching/fatiguing and tearing... This is not an ad for Flexx Boot...I just know they can stretch quite a bit... |
I use these c/v boots, combined with the high-angle / deep-plunging c/v joints from McKenzie Performance in the OC (no affiliation). Also assembled with Krytox brand lube.
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
Racer
What fore/aft angle are you seeing with your axles? Jack, or anyone else: What angle does the 87-89 Carrera have? Compared to a 915, the G50 style gearboxes have the output flanges about an inch farther forward on the car. So a 915-based car will have less angle.
