Bosch CIS injector numbers and substitutes
I hope Tony will pick up on this thread:
My car has some irregularity at idle and hesitation/surging at cruise. It runs smoothly at wide throttle settings. I tend to think this is due to poor fuel atomization, so I'm considering changing the injectors.
I'm seeing a range of pricing on the same Bosch part number, 0437 502 004, from $36 on up to $70 or so. Other numbers associated with this injector include: 028851079518, 3165142315812, 62281, 911 110 225 01, 911-110-225-01, 911-110-225-01-M14, 911.110.225.01, 91111022501
I also saw a different part number for Mercedes, 0437 502 047, set of 6 for $132. Those were listed for a variety of MB engines, but with similar size cylinder displacements. If they are physically compatible, those should work too.
Has anyone tried different injectors in their Porsche CIS engines? Are there compatible injectors for MB, BMW, VW, etc. that work well and cost less?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
