JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Question Clutch not catching
I just want to run a diagnosis past yall. '83 SC with original 3.0L and 915 transmission.
We just mated the motor and transmission back into the car last week. I had a timing issue that prevented the car from starting, but have corrected that today.
I feel sure we mated the transmission correctly. I had the clutch release fork in the same position as when the transmission was removed. I re-used the helper spring and re-attached the clutch cable which was replace about 3,000 miles ago. the pressure plate, bearing, etc were all replaced at about 30,000 miles ago. Prior to the seperation everything was working well.
When pressing the clutch pedal it feels as though there is no resistance for about 1/3 the travel of the pedal. At full depression the transmission grinds. I have not forced the shifter.
I think that either I have not fully "tightened" the clutch cable or that I have the clutch release fork in an incorrect position. Thoughts, opinions? Once again, I really appreciate it!
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 06-07-2003, 02:27 PM
Elombard's Avatar
I think you may have not got the clutch arm meshed in with the TO bearing :-0 I hope not I think this is engine back out item?? I almost missed this on mine. YOu have to look through the opening in the top of the tranny to see if the arm engaged the TO bearing
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-07-2003, 02:37 PM
