915 trans 7:31 R&P
I was just reading a thread in which the 915 7:31 ring and pinion combination was referred to as weaker than the later 8:32.
Is that true? Elsewhere I read changing to the shorter ratio gives better torque to the ground, without no mention of durability concerns other than those associated with a mag-case 915.
Which is correct/ can both be correct?
Sent from my Pixel 7 using Tapatalk
Old 01-25-2023, 10:35 AM
H-viken's Avatar
Both are correct. The 7/31 ratio is weaker from a longevity perspective and it accelerates the car faster
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 01-25-2023, 10:44 AM
gearhead
There’s threads on it here, but going from memory I want to say 16% less strength for 7:31. I still sell quite a few of them because they do offer better acceleration. Both are true.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-25-2023, 10:47 AM
Bill Verburg's Avatar
As mentioned both are true
there is a trade off for better acceleration
the higher numerical ratio of the 7:31 also shortens the useful range of speeds and time in a given gear
Bill Verburg
Old 01-25-2023, 11:33 AM
targa72e's Avatar
I believe you can also do a 8:35 for lower ratio but stronger than 7:31.
john
Old 01-25-2023, 12:48 PM
Thanks y'all.
Old 01-25-2023, 01:56 PM
Walt Fricke's Avatar
John - I've never seen reference to an 8:35 for an OEM Porsche with a 915. Maybe a 901 or a Sporto (both of whose gear sets aren't interchangeable with the 915 due to different shaft separation if I remember right)? I seem to recall a 6:something as a hill climb gear for the 901?
Old 01-25-2023, 05:15 PM
gearhead
I used to make them (with Ricardo). Tandler and Albins both make them now, but they aren’t OEM quality for quietness and lifespan. They are more Motorsports parts.
1974 914 Bumble Bee
2009 Outback XT
Old 01-25-2023, 05:31 PM
Thank you Matt your input is always appreciated -
If you give your word: keep it.
Old 01-26-2023, 09:08 AM
gearhead
You’re welcome. Happy to help when I can.
1974 914 Bumble Bee
2009 Outback XT
Old 01-26-2023, 02:45 PM
Hi Chris
Trying to send you a PM but your box is full, need to clear some out
Thanks, Rick
Old 04-30-2023, 09:29 AM
