'73 911 T Targa
How to get this apart?
What’s the trick for disassembling this?
The fitting is evidently attached to a tube that goes through the tunnel, so I’ll need to hold the fitting while removing the line, bit there’s not enough room to get a wrench on the fitting to hold it. Any thoughts? |
'73 911 T Targa
A little more comtext would help.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Needs a flare wrench (or a crows foot flare wrench) on the right side (nut) and perhaps a vice-grip on the fitting side to hold that firm. Clean the black coating off the nut. Also note the retaining spring at the base of the fitting, at the bulkhead; that is there for some reason.
Grab the 90 degree fitting with vice grips and put the proper flare fitting wrench on the other. You’ll have to clean the chipgaurd off the nut so the wrench will fit. Don’t use a regular or adjustable wrench or you’ll strip it and have bigger problems.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Flare wrench
What is that, brake line to the rear? Why ya pulling it apart?
1982 911SC |
It’s the brake line for the front.
'73 911 T Targa
It’s in the front, but it’s going to the rear.
I’m removing it so I can get to the adjacent fuel lines |
You must be able to get a spanner on the square section to hold it whilst undoing the pipe union, or am I missing something?
