No longer impossible! 996/997 transmission onto air cooled engines!
Product I've been working on for the last year will soon be available to all...
Swap kit for 996 / 997 six speed (NA) transmission onto air-cooled Porsche engines! Completed on my test mule '75 911 using 996 transmission, I've put about 500 miles on the setup so far and driving it more every day. What a huge upgrade it is! These transmissions are not only cheap and easily available, they shift amazingly well in all conditions. Shifting at 7000 rpm just takes a flick of the wrist! No more gentle, deliberate waiting for the older boxes to behave. The stock gearing is absolutely a delight! The first few gears are nicely a little shorter, the 6th gear makes cruising on the freeway fantastic. Something like 2800 rpm at 80mph. Plenty of different limited slip units and ratios are available for these boxes as well. Even the reverse gear is synchronized and silent. Every gear is a breeze to select! Having both the 996 and 997 boxes opened up, they are build very well with wide, strong gears - similar to the beefy g56 style units I work on with the 959s. I can't imagine ever breaking one of these with such a light weight chassis. And if you did, you can pick up one of these for about $2k all day long. For the early chassis - this is not a job for the faint of heart! Requires completely cutting out the areas between lower control arm mounts, torsion bar tube etc. I already had coil overs and don't care at all about the useless backseats, so not a concern for me. The rear seat "hump" must be changed to 964/993 style "high hump" I plan on making a rear seat delete / luggage dump to cover it all up nicely. Linkage is cable which is fantastic. Numeric racing makes the cables and it's easy to adjust / extend the ends. I'm also using the Numeric racing shifter unit, which has more adjustment and removes ANY slop in the system. The shifter is bolt action rifle feeling, while not transmitting any noise or vibration into the car. The adapter system consists of a 1/2" 6061 aluminum plate CNC cut. This locates the transmission centering onto the air cooled engine. A special flywheel / clutch / release bearing assembly makes everything work with factory 997 hydraulic release cylinder and arm. The starter located by the adapter plate, and the mini starter is required. A special adapter for the starter allows perfect fitment and easy service. Stock engine mounted oil cooler is a no-go. I've also developed a replacement plate for the stock cooler that allows AN fittings to your tank and cooler, using the stock in -engine thermostat. Axles are easy! Your stock axles work with simply knocking out the locating pins and drilling out for bolts on the transmission side. This is only for the 94mm CVs. I may develop an upgraded, direct fit axle for the swap at a later time. Brake lines and ebrake tubes need some massaging. Easy part of the job. This may not be as much of a factor when I finish the design for a CNC transmission mount. My current mount is plate stainless, welded together. The shifter bracket is completely custom and relocated on the transmission. The forward / backward attachment point is moved to accommodate. For the later, 964, 993 chassis this swap with be FAR easier, probably only really requiring room for the shift cables etc. Also a great unit to use with any other air-cooled flat six powered vehicle. The adapter plate may also work with the newer 7 speeds, PDK, and some automatics, more research will be done here... Lots of pictures and videos to come, this is an exciting upgrade that's really made me fall in love with the car all over again. I can't get enough of the driving experience now. Feel free to ask any questions here or in my PM.
North Idaho CDA / Spokane area Instagram: to.performance MoTeC USA Authorized Dealer Porsche 959 Department Manager at Canepa *retired after 10 years* Website / Webstore https://www.topperformancetuning.com/ Last edited by TopTuning; 05-04-2023 at 10:55 AM.. |
North Idaho CDA / Spokane area Instagram: to.performance MoTeC USA Authorized Dealer Porsche 959 Department Manager at Canepa *retired after 10 years* Website / Webstore https://www.topperformancetuning.com/ Last edited by TopTuning; 05-05-2023 at 01:38 PM.. |
![]() Timeline?
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod. |
Need to put some more miles on it before it's available, as I do with everything I offer!
Soon though ....
North Idaho CDA / Spokane area Instagram: to.performance MoTeC USA Authorized Dealer Porsche 959 Department Manager at Canepa *retired after 10 years* Website / Webstore https://www.topperformancetuning.com/ |
82 911 SC - Ancora Imparo
Sounds like everything before the 964, based on his initial post...
Ethan 1982 911 SC - Wine Red Metallic Coupe |
Not sure why pictures aren't working...
lake wales fla
What pedal assy are you using
Richard |
gearhead
Who is making gears for them?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
kinda slow
Subscribed, love all the stuff you're doing for these cars. Keep it up!
1983 911 SC Coupe |
I've been curious about this being a possible thing for some time now. Awesome to see someone else actually making it happen. I loved the transmission in my 996, and wish my 915 could take the shifts my G96 could.
Looking forward to seeing pictures of the modifications. Do you know the weight difference between an aluminum 915 and these gearboxes?
Cars and Cappuccino
Subd. Pics please
Following
Sent from my iPhone using Tapatalk |
Congrats!
You are really on a roll with the new products lately, nice stuff. |
Constitutional Liberal
Will your adapter plate support the Cayman transmission?
Obvious question, fitment in a 914/6.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Under the radar
Waiting to see what torsion bar tube mods need to be done.....
Amazing! This is exactly what I was looking for
G96 175lbs (https://californiamotorsports.net/pages/porsche-996-c2-c4-transaxle-specifications)
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
1982 911SC |
