Project Karl - noisy 915 on first drive :-(
Hey all,
Our 84 911 outlaw hit the road for the first time the other day. It was absolutely incredible for it to leave the driveway.
Everything seems to be working great, except we have a strange, grinding / rattling noise in 1-4 gears and neutral when rolling forward. 5th is totally fine.
The car has an LSD from wavetrac and numeric shifter along with wevo side plate and wevo gate shift. The transmission was rebuilt. In hindsight, he came highly recommended but I don’t know how experienced he was with 915 / diff set up.
When moving forward, the only way I can get the noise to stop is to push the gear lever all the way to the right or to shift into 5th. It does not change pitch at all based on the speed of the car. It is consistent at all speeds and all gears as long as the car is rolling forward. If I am rolling in neutral with the engine running, the sound is the same. If I turn the engine off and continue to roll in neutral, the sound goes away. It does not seem to affect the drivability of the car. I have only driven it a few miles. But the car seems to drive fabulously.
Here is a YouTube vid of the sound. https://youtube.com/shorts/-0695k-QuGA?feature=share
I guess it could be a shifter adjustment or something far more complicated.
We are so close to having this car on the road! Your help is appreciated. Here’s a pic of Karl on public roads for the first time!
Old 05-13-2023, 10:31 AM
Discseven's Avatar
That is one nasty---in a beautiful way---looking Porsche Sean. Looks black but I know photos can be misleading. If it is and the wheels are black... work of art. Something about a flared 911 with no tail...Unordinary. The 5th gear thing, I'd be looking at shifter linkage beginning to end. Sound fits the look---nice growl.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-13-2023, 02:54 PM
Can you feel the rattle in the shift lever?
'80 SC Targa
Avondale, Chicago, IL
Old 05-13-2023, 03:12 PM
Yes for sure
Old 05-13-2023, 03:41 PM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Are you using "Sport", semi-solid, or solid engine/trans mounts ?
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 05-13-2023, 04:05 PM
Thank you!!!
It’s Irish green with brushed bronze wheels.
Time to figure out the transmission and let this thing sing!!!
Old 05-13-2023, 04:07 PM
Wevo semi solid
Sounds like another thread here recently. I suggested maybe the 5th/reverse shift sleeve was adjusted too close to the reverse idler and was rubbing teeth. It was apart, so...
206 637 4071
Old 05-13-2023, 06:04 PM
Yes I read that thread and very similar issues. The difference was that he had the sound with the engine off and mine immediately goes away if I switch off the engine while in motion.
I really don’t want to pull the drivetrain but I think that’s where we are headed with this :-(
Anyone else have insight?
Old 05-14-2023, 05:35 AM
Sounds to me like something is touching the exhaust tubing or maybe a heat shield somewhere. Sound change in a left or right turn?
I would do a lot more looking before dropping the drivetrain.
Old 05-14-2023, 07:51 AM
Karl seems to pull pretty good, to me it doesn't sound like
You have to drop the trans. Did you check your clips for the
Throttle rod? Sounds like it's rattling under the tunnel.
Good luck.
Old 05-14-2023, 08:11 AM
The problem is that it immediately goes away when I push the shifter all the way to the right and comes back as soon as I release it.
Old 05-14-2023, 08:17 AM
Do you have a two post lift? Is the sound still there with no weight on the suspension?
Anyway wish you the best.
Old 05-14-2023, 09:05 AM
I can give that a shot…. Good suggestion !
Old 05-14-2023, 09:16 AM
