Frunk Light Mount Location
Ordered a new frunk light to go in the empty cavity where one should be in my '87 Coupe. Wires are there and both functioning properly, so piece of cake, right?
Well...the light housing and the hole don't match up and there's only one screw hole. The light housing is much bigger than the existing hole. I know my hood has been painted and it seems that it may have been replaced as well.
Any thoughts on potential remedies? And why the hood doesn't have the correct mount?
-Mike
1987 911 Carrera Coupe
Old 05-15-2023, 07:29 AM
Hood light
As a reference here is my light assembly.
The dimensions of the hole on my hood is 1.98 in by 1.92 in.
My car is an 82. The lens is Hella Sae L71
Old 05-15-2023, 07:49 AM
PET shows 2 different PNs for your car, maybe thats the issue?
901 632 201 01
959 632 201 00 ( this one looks smaller )
Old 05-15-2023, 08:13 AM
pelican indicates the shape/design changed for '84 and later 911s -- see https://www.pelicanparts.com/More_Info/99763220100.htm?pn=997-632-201-00-OEM&gclid=Cj0KCQjwsIejBhDOARIsANYqkD04qQ1B63m8CCS5Ryui llsejIm6OHmNTL4VudLKSKBL55RGNEI7hawaArGvEALw_wcB
Old 05-15-2023, 08:15 AM
901 632 201 01
The light that I bought is that first one. Before buying I also did some under-hood stalking of '87's on BaT and the light I have matches what's on other '87s. See below for a screen grab from an '87 frunk light...looks just like what I have, which is why I'm wondering what hood is on my car.
-Mike
Old 05-15-2023, 08:31 AM
-Mike
Old 05-15-2023, 08:32 AM
The front trunk light is the same from 74-89. The brackets on the lens that holds the light assembly should measure 1.96 inches. If you never had a light assembly there when you acquired the car then someone else realized the problem and left it. If it were me I’d measure what the hole should be which is the dimensions I gave you. Tape the perimeter, get out my dremel and a drill for the second hole and go to work.
Old 05-15-2023, 08:41 AM
My 84 has the bubble frunk light. Is that sticker a VIN sticker on the hood? Is it your VIN.
Old 05-15-2023, 08:42 AM
Just measured and my opening is 1-3/4 x 15/16, so definitely needs to be opened up.
That last image isn't from my car. My car does not have a sticker in that location.
-Mike
Old 05-15-2023, 09:00 AM
PCA Member since 1988
FYI, when I replaced the light bulb with a brighter LED bulb on my 1973, I also bent up a small reflector out of thin aluminum flashing to go over the bulb and reflect more of the light back down into the frunk, instead of up into the backside of the hood. It helps.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-15-2023, 04:12 PM
Took your advice an ran with it. Not going to win any metal cutting awards but it’s all hidden behind that nicely functioning light. Thanks for the help everyone.
-Mike
Old 05-19-2023, 03:13 PM
