SPE SPE is offline
Warning Light
The Fasten Belts warning light on my '82 SC stays on regardless of belts fastened/unfastened and seat occupied/unoccupied. The warning buzzer functions normally. My owner's manual states that the light should extinguish after 6 seconds. Any ideas to fix this?
Thanks,
Swen
Old 05-25-2023, 02:28 PM
There's a very early style circuit board in the warning light housing, mine wasn't working and found one of the soldering joints was broken inside. You can pull it out carefully from the dash and undo the wire connector behind. Taking it apart is easy also. These parts are no longer available.
Old 05-26-2023, 04:07 AM
proporsche's Avatar
before you start messing with it- it is a pita to get to when you remove the clock...Put your key on and disconnect the battery for couple of seconds .reconnect and report if that helped..?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-26-2023, 07:53 AM
I was able to wiggle it out without removing the clock.
Old 05-26-2023, 08:48 AM
proporsche's Avatar
you were lucky ..there are four security clips which hold the unit in place..
Old 05-26-2023, 11:12 AM
