Idle stalling
Hi everyone,
I just bought a targa 85 euro model. I have a problem with the car stalling on a cold start. I’ve notice a hose disconnected at the back of the flap connection. This hose goes from the oil tank to the air body right above the Y See photo. Could this cause the problem? ![]() |
PCA Member since 1988
Short answer, yes. Plug the hoses and see if that works. Then plug those hoses into where they are supposed to go.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I am waiting on few parts and will try! Thanks |
If its the y vacuum line one goes to the fuel damper and one to the fuel regulator
you also have some cracking on the other line. I would look to replace that one sooner than later.
You should get a Bentley manual. And 2 meters of vacuum hose to replace the old vacuum lines. There should be a vacuum line routing sticker in the engine bay.
news
thanks guys.
I will replace all these hose,Y, clamps. No I am waiting on my fan and housing to be refurbished... I also sent the ECU to be checked at ECU Doctors...It might be something wrong with it... Keep you posted |
Thread Tools | |
Rate This Thread | |
