Go Speedracer, go!
SpeedracerIndy's Avatar
3rd break light
I read the tech article on adding a third break light. I want to do this because I always get nervous when I see big SUVs bearing down on me and wonder if they are going to drive right over my low tiny SC. The tech article mentions the use of an LED stip purchased at AutoZone. I have looked at all the local auto parts stores and cannot find anything similar. Anyone know where to find one similar that will be easily hidden and not look like it was added on?
Old 06-07-2003, 02:04 PM
Just put the same one on my targa last week but tossed the packaging material out..sorry. Indianapolis has about 12 AutoZones if they don't have it they can order it for you.
On the Targa, if fits up against the glass and against the back of the Targa padding. I just took the little swivel thingys off. Can't see it in the mirror or from outside at the rear. Seen only when its on. Could have been a factory fit item it fit so well. On a coupe, I guess you would still need the swivel thingys to mout it. Wouldn't look as good.
If it doesn't leak, you're out of oil.
If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt.
Screw Flanders....
I'm goin' to Moe's.
Old 06-07-2003, 05:36 PM
nostatic's Avatar
anyone run one of the cab 3rd brake lights (out of the top of the engine lid)? That seems like a reversible solution that's easy to wire, although I'm not sure how they mount.
Old 06-07-2003, 06:20 PM
J. C. Whitney has a few different models and so does Pep Girls.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 06-07-2003, 07:44 PM
Go Speedracer, go!
Never thought about Pep "girls" or JC whitney. Thanks for the info. Was there a part number on the Autozone part?
Old 06-08-2003, 05:51 PM
Made by Pilot. #WE6-197
AutoZone # 124001-1
Screw Flanders....
I'm goin' to Moe's.
Old 06-09-2003, 01:19 PM
Go Speedracer, go!
Thanks! Found it.
Old 06-09-2003, 04:38 PM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
If it is for a Targa and you want to do something more Porsche-like.. look at the PN 951.631.060.00, not from a 911 but 'blends' very well with the rear Targa window.
Jordi Riera
'84 930 (modified)
Old 06-09-2003, 04:55 PM
Go Speedracer, go!
It's for an SC coup. Has anyone installed a factory 3rd break light from a Carerra on an SC? I noticed on PelicanParts that the targa version (like those on the 88) is only about $50. WOuld this fit on a coup or would I have to do some modifications?
Old 06-09-2003, 04:58 PM
