Help me get my intake manifold back on - cap nut loctite vs antiseize, reuse old hard
Hoping fellow pelicans can get me sorted out - in a bit of analysis paralysis getting my intake back on.
I see threads about lock washers, wavy washers, not to reuse old hardware, ok to.
Anti seize and if so what’s the modified torque value and some saying blue loctite.
First time I’ve done this - engine has 120k on it and have original hardware with flat washers. Obviously putting new spacers and gaskets on.
Can anyone recommend whether I should re-use my hardware and antiseize or loctite?
Have read a bunch of threads after going down this rabbit hole and while I don’t want to mess anything up really want to drive this again!
Thank you
Old 06-26-2023, 08:21 PM
Slippery Slope Victim
NY65912's Avatar
I used the old barrel nuts with Belleville washers. Nothing has loosened in 7 years.
https://www.mcmaster.com/products/standard-washers/lock-washers-4/belleville-spring-lock-washers-for-socket-head-screws/
Mike²
1985 M491
Old 06-27-2023, 02:38 AM
I just used the same copper coated slit-lock nuts as I used for the exhaust, with some regular ass zinc plated washers underneath. Edit: The copper plated slit-lock are nice because they're designed to use a 12mm wrench instead of a 13mm, which helps with access.
https://belmetric.com/slit-lock-nut-copper-plated-steel-exhaust-din-14441/?sku=NC8X12
1982 911SC
Old 06-27-2023, 04:56 AM
Targa_PB_78_SC
mike sampsel's Avatar
I've reused the self locking 12 mm nuts which were original, several times. Get them good an snug, have not used a torque wrench (not enough room). With new gaskets every time, the runners indent them. Never had a leak at the runner or a nut come loose either.
BareRearedRookie
Old 06-27-2023, 05:35 AM
Thanks all. What about antiseize or loctite?
Old 06-28-2023, 08:49 PM
Targa_PB_78_SC
Anti-seize when fastening two different types of metals like aluminum and steel for long time so a reaction doesn’t cause seizing, so no here. Blue loctite unnecessary these nuts don’t go anywhere. But don’t mix the two, seriously if anything would make you sleep better, use blue loctite, but not for me, too messy in those quarters.
There is an old thread on antiseize use on plugs. Some do, some don’t, I do not. If you change your plugs often enough no worries. This is the steel plug aluminum case situation. I used antiseize on the oil temp thermostat where the steel oil line meets the aluminum thermostat, and antiseize in exhaust nuts and bolts, no where else.
Cheers
BareRearedRookie
Old 06-29-2023, 02:48 AM
I found the new commercial barrel nuts to be shorter than original thus the stud pushes the hex up and less room to grab the flats of the hex. They don't loosen, its the double gasket and spacer compressing.
Old 06-29-2023, 03:13 AM
PCA Member since 1988
Because these are friction nuts, I have not had them loosen up. In fact, the opposite--they are tight enough that I backed out one of my head exhaust studs when removing the heat exchangers. I use the 12mm copper nuts and anti seize. I have a Snap-on 12mm 1/4" drive socket that just fits straight up through the tubes in the SSI heat exchangers, which allows me to put a torque wrench on those nuts. even so, I don't normally use a torque wrench, just feel.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-29-2023, 02:26 PM
Cheers
Thanks yeah I feel the same way - i don't want loctite in there - unless this is requisite to not have them loosen.
Appreciate your confirmation. Look forward to getting these back together today!
Old 06-30-2023, 07:32 AM
Thank you for the detail! Much appreciated.
Old 06-30-2023, 07:33 AM
