l_turn9's Avatar
Need Tips for Installing Rubber on Rocker Cover
I need to install the protective rubber strip that fits on each rocker panel cover of my 74 911. I've tried 3 or 4 different approaches and I'm just not getting anywhere. I'm using water & Dawn to lubricate it and am hoping someone can provide some other tips.
Thanks to all -
Old 07-22-2023, 02:37 PM
I don't understand what you are asking. Post a picture.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-22-2023, 04:30 PM
I think it just slides in, not sure there is any trick, but the soapy water should be doing the trick.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 07-22-2023, 04:31 PM
Wet silicone spray, do the bottom first then twist in the top starting on one end. Keep it siliconed as you go. I recall the factory said just push it through, but good luck with that. Actually have to do one now.
206 637 4071
Old 07-22-2023, 04:41 PM
917_Langheck's Avatar
Add some heat to the water and soak the rubber to warm it up and make it more pliable and stretchy.
Old 07-22-2023, 04:43 PM
l_turn9's Avatar
Thanks to all who replied and offered great suggestions. Seems like there's no "easy" way. I tried to slide it on and once about 1/3 of it is in place, the friction is so great that it will not slide anymore.
I really appreciate the suggestions!
Old 07-22-2023, 05:04 PM
Make sure there are no burrs or sharp edges on the metal rail that the rubber slides onto. Then generously lubricate the rubber with KY Jelly. I mean like a whole tube. Then push and pull like hell. It can be done.
Old 07-22-2023, 05:51 PM
I did mine with very hot soapy water in a squeeze bottle and made sure the groves in the rubber had no grit at all before hand. I lubed the metal rail, top and bottom with straight dish soap
Old 07-22-2023, 06:08 PM
47silver's Avatar
Used dawn and hot water and created some new swear words while pushing it from the rear. Easier than a targa rear window. 2,people might be easier.
Old 07-27-2023, 05:52 PM
What's helped me tremendously with any of these devilish rubber trim pieces is using cable pulling lubricant. It is an entirely different level from using silicone lube or soap and water. It's a little more expensive but totally worth it.
I think this is what I have out in the garage: https://www.grainger.com/product/10F523?gucid=N:N:PS:Paid:GGL:CSM-2295:4P7A1P:20501231&gclid=CjwKCAjwzo2mBhAUEiwAf7wjkhujK4-NvoRds6Ni2Tgm_e1E24RR5rXduFqEV5raqsEtB0PYMy-aNxoC2lYQAvD_BwE&gclsrc=aw.ds
It's designed for pulling heavy cables jacketed in rubber that are hundreds of meters long. It just works.
1982 911SC
Old 07-28-2023, 06:25 AM
I used dawn and hot water.
Brewster Green 1977 911S Outlaw
Hot 2.7|10.5:1|Single Plug|Knightrace Cams|Weber IDA40's|SSI's|MSD Ignition
Engine Built by Will Pyle
Instagram: indy.alex.g
Old 07-28-2023, 06:34 AM
GG Allin's Avatar
It doesn't hurt to let them sit in the sun either. I've used WD40.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 07-28-2023, 08:15 AM
I recently installed these on my 911. Sliding them didnt work. After a foot or so they wouldn't budge any further. I ended up installing them on the bottom groove and then took a trim removal tool and pushed down a bit and towards the car to get the upper lip locked. Just kept doing this along the entire length. Went pretty easily that way.
Old 07-30-2023, 01:21 PM
47silver's Avatar
Thanks that sounds like the way to do it
Old 07-30-2023, 04:41 PM
proporsche's Avatar
yes last time i did it was this technique....good job..plus liquid soap...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-31-2023, 02:10 AM
Tags
911 , rocker panel , rub strip
