Harder to get to redline
One characteristic of my car has been that it's almost too easy to hit redline on it in first gear if I really get on it - I have to be very careful because it shoots right up almost instantly.
However today, I noticed that I was having a lot of difficulty getting it past 5,000 compared to the usual. Power seems okay. I thought it might be the alternator load from the A/C so I tried it with the A/C off and it was the same. Any ideas what it might be? 1978 3.0 CIS motor, running fine otherwise. It was pretty hot and muggy today and air quality is really bad due to forest fires north of the city, could that be it?
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
Could it be that you are not able to get to WOT? Maybe something in the pedal cluster? You think you are mashing to the floor stop, but not able to get it there? The only way I can think to rule that out is manually open the throttle vs using the pedal. See if you can achieve the same with both.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Is your air cleaner clogged?
Matt |
Banned
Lots of good resources here if you search for throttle linkage bushings. |
Toronto’s barometric pressure is normal at 29.84 and has been quite steady recently. That shouldn’t have any noticeable impact on performance.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
It has about 2,000 miles on it but I'll take a look. I did the pedal cluster but not anything past that. I'll take a look and see if there's any play.
Don't know how many miles are on it but a possibility is a broken valve spring. I'tll be strong enough
at lower rpms but valve float will happen up high.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
Hmm, the motor is a fresh rebuild with about 2,000 miles on it now. Any way to tell if a spring is broken without dropping the engine?
Still here
Oil's no good.
Didn't know it was a fresh motor. Valves will seat after the heads are reconditioned. |
1. Mixture too lean or too rich (CIS troubleshooting on all aspects)
2. Ignition timing wrong 3. Throttle plate does not fully opens as it should 4. Fuel pressure too low 5. WUR control pressure not correct (see point #1) 6. Vacuum leaks after overhaul (sufficiently testable with a smoke generator only!) 7. Does the tachometer still works correctly? Crosscheck the rpm with an ignition timing gun with rpm display Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 07-04-2023 at 07:27 AM.. |
There's other good suggestions here but regarding the springs-if you check valve adjustment you can try pushing to see if any valves open more easily than others.
Seat pressure is only around 65 pounds.
I've been having hard cold start issues so I figure I'll get that done and talk to the mechanic about the issue. I thought I'd finally whipped most of the CIS issues but who knows.
I took it out for some errands and once it was warmed up I tried again and it was a bit better, but it's probably due for a valve clearance check anyway. Thanks for the suggestions!
Good luck |
Still here
So, a followup from my visit to the mechanic.
It turns out a previous mechanic had left an allen key in the enrichment adjustment hole on the top of the fuel distributor, and it had migrated down and jammed itself in against the metering flap, literally preventing it from moving properly. Once it was removed the car was totally fine and it's back to pulling hard to 6500. Wish I had checked that myself!
PCA Member since 1988
Thanks for the resolution. Good to hear it was something simple. Sorry to hear it was something avoidable.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
When Did It Happen?
Jeremy, You drove your car from Toronto to Pennsylvania and visited me in late April and it was running very well. So when did the mechanic work on your car? Before or after Carlisle Swap Meet? BTW, whatever happened to the WUR I shipped to you? Thanks. Tony |
Still here
Good thing it wasn't a banana or equivalent in the tail pipe !
