Several questions
I have a 89 3.2 it has been lowered. I would like to raise it back to stock.
What are the stock heights at the fender lip? It is currently 24 inches. I think I will have to re index the rear bars? What is the degree angle for the stock height at the trailing arms?
I would like to place the rear wheels in the front and install wider rear wheels. What are the replacement sizes for the rear? Tire size?
Old 07-26-2023, 02:15 PM
PCA Member since 1988
Stock US height or stock Euro height? Not sure if that matters on 89's, but at least in the earlier cars the Euro was about a half inch lower than US.
Euro height on earlier cars is nominally 25.5" at the front fender lip, and 25 at the rear, measured on a FLAT level surface. Someone else will jump in with the Porsche spec for measuring the differences between heights of suspension parts and insist that's the only "right" way to do it, becuase the cars are hand-built and slightly different from each other, etc. But as a practical matter, you end up in the same place IF you are using stock-diameter tires. If you have different diameter tires, then add or subtract the difference in the radius to the fender height measurement.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-26-2023, 02:26 PM
Not a fan of using the body as a measuring device.
Do it the factory way to Euro specs and scales to fine tune.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-26-2023, 06:48 PM
https://www.elephantracing.com/tech-topics/spring-plate-angle-calculator/
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 07-27-2023, 07:15 AM
