LinkBack | Thread Tools | Rate Thread |
911 SC -- AC blower (over condenser in smugglers box) -- is it dead or not?!
Hi all,
I have an '83 911 SC. Since I bought the car 3 years ago, the AC blower fan (center vents, NOT the fresh air fan) has squeaked and clicked. Well, it flat out didn't turn on the other day. After leaving the AC "on" for a couple minutes, smoke creeped into the cabin from the center vents (AC vents). Dead fan, then? So, I pull the AC blower fan out from the smuggler's box (PITA), and it looks perfect. It doesn't have any obvious play about the shaft. It does seem a little difficult to rotate, but not "notchy". Just tight-ish. Easy enough to spin by hand, but no way would it continue to rotate without some small force. So I hooked it up directly to a 12V car battery, and it spins! Not fast... but it DOES spin. So before I replace it, how can I know for sure it is bad?! Should the squirrel-cage spin more freely? Where did the smoke come from if the motor looks fine? Is there something else that could be smoking through the vents? side question: I have a spare fresh air blower fan (bought the wrong one at a swap meet - D'oh!). The motors wouldn't happen to be interchangeable, would they? Does our host sell the motor I need? I couldn't seem to find it. Thanks all! |
Fleabit peanut monkey
In Pelican's parts list
Pelican Parts - Product Information: 911-624-899-00-M207 Griffiths sells a high output blower motor direct. Big price difference. Not sure if they are the same part but from pics looks like the PP blower has add'l hardware for mounting. A few phone calls would be prudent. 911/930 Kuehl Wirbelsturm Evap Blower Motor 70-85 911 evaporator blower motor, 930 evaporator blower motor, 901-624-901-00, 90162490100, 901 624 901 00, 901.624.901.00,911-624-899-00,911 624 899 00,91162489900,911.624.899.00 [911930KuehlWirbelsturmMo Fresh air blower is not the same motor.
1981 911SC Targa |
Don't forget to check for mouse, nests, droppings, even baby mice. |
Blow out any dust, etc with compressed air, then lube the bushings really well- you may be able to save that fan motor-....... for a while.
Tim |
At 12vdc, providing at least 12-15 amps, with the blower fan attached to the motor, it will spin quite fast, fast enough to fly out of your hand. Hence it sounds like your motor is shot.
Best upgrade with detailed instructions is this one hands down: Pelican Parts - Product Information: 911-624-899-00-M207 Last edited by kuehl; 06-01-2013 at 07:45 PM.. |
$375.00 is a LOT of DIY modivation.
Disassemble the motor, use emery cloth to burnish the commutator, replace the brushes, clean and lube the sleeve bearings/bushings. |
edited
Proof...? |
Thank you for the links! I will consider them if I can't get my existing fan back running
![]() Quote:
As much as the Kuehl motor seems like a nice way to go.. I have to wonder.. the inherent cooling of the AC system will not be changed by the blower, correct? I haven't looked at refrigeration cycles since my last thermo class a few years back, so I don't remember a lot. The big gain of the supposed 30% MAF improvement would only serve as forced convection when the ducts are aimed at the passengers. Living in california, I don't think I need the extra flow anyway. I will avoid spending on this project if I can. I have other goodies I want, and I set a very specific budget for the old girl. You'll see me at swap meets if I can't revive this AC fan.other note: stuck a multimeter on the fan plug from the car. With the AC turned on, it is getting its full voltage, so all the wiring up to the fan looks good. I think it's just tight on the shaft. I'll post my luck at reviving it from the dead ![]() Thanks everybody so far! You've been very helpful |
30% more system airflow will only help if the evaporator core temperature doesn't rise accordingly(***). Provided the evaporator temperature remains fairly low the big gain would be quicker initial cooldown of the cabin.
Most of us "turn" to more moderate system airflow as/once the cabin cools. *** In my opinion the major shortcoming of the Porsche factory air of this era is the lack of adequate condensing capacity. Follow Porsche's lead on this, the very first substantive improvement they made was to add the condensor/blower behind/under the front bumper. And then there is the aftermarket providing various versions of additional condensing capability. So, provide enough condensing capacity and the evaporator core temperature might well remain (more) stable as the rate of airflow rises. Last edited by wwest; 04-17-2013 at 08:41 AM.. |
Hey wwest,
how did you get the motor apart? I've got it out of the plastic housing, but I'm not sure how to split it. There's no bolts/clips in sight. |
pictures attached:
The motor looks to be in OK shape, but it definitely has some resistance. I am not confident that even if I could get it apart that I would be able to truly revive it. There is a small motor repair shop 20 min away. I'm going to drop by tomorrow and let the pros revive this old hunk of metal. I can't imagine it will be too much $.
But first I would use WD40 to clean/rinse both shaft bearings and then soak the bearings with light machine oil (10 weight) before and while the motor is running. A lot of end-play would indicate a need for a thrust washer replacement. I would replace the commutator brushes simply as preventive measure. The pictures seem to indicate that the brushes are on their last leg.... Last edited by wwest; 04-18-2013 at 09:12 AM.. |
Great pictures!
Well, the local shop was completely unhelpful. After a 25 min drive each way, I am no further. I called before and they said they can take a look and it shouldn't be too hard. After I got there, he took a look, seemed to be very confused and said it would take him a while so I'd have to come back in a couple weeks. Great.
I called Bosch, but they said the motor was only made specifically for Porsche, so only Porsche sells it. I will be looking for good-condition used motors. We'll see what comes of that. In the mean time, I guess it's back to breaking it apart. I'll get a chisel. Thanks for the help, wwest! |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Put the chisel away.
The only "tricky" part in replacing these motors is removing the old one without damaging the allen set screw. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 04-18-2013 at 05:01 PM.. |
Do you mean the allen set screw on the squirrel cage? Mine came loose quite easy. I hope I didn't break something. It seems to screw back on just fine. |
Motor I.D.
not according to the posted description.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
