Engine running Hot all of a sudden
Hi 911 people,
I was driving my 82' SC Targa (CIS injection) yesterday and noticed all of a sudden that the temp was higher than usual.. It used to run slightly above the 1st white mark on the temp gauge but now close to the 2nf mark.. And it just smells like it running hot.. In New Hampshire, 72* out... Any ideas what to look at? -Yes, belt is on and fan is spinning normal. -I also touched the oil to the front cooler and it was hot, so oil it going up to the cooler.. -I don't feel any air leaks when running. -BTW, engine is off, I just turned the key on for picture, that why no oil pressure... Also, later, after it cooled it was hard to start, and it always started right up??? ANd runs a bit rougher.. Thanks in advance, -Bill
Maybe something made a nest on top of the piston cylinders?
Hope this helps.
Rich Franco Northern Virginia 1980 911 SC Targa |
Check ignition timing and mixture.
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
-Bill |
