Super obscure photo Request
Does anyone have experience with - or know anyone that - took a 3.2 carrera (factory 9" wide rear / 7" wide front) and only widened the front of the car to the 930 turbo 9" width? making it 9" wide squared on all 4 corners? In my opinion could make for a unique looking appearance to the car. Would love to see photos
Registered Minimalist
Never seen that, but I'll bump your thread and tell you about the 930 rear flared car with narrow front flares. It was a bit weird. I had a folder on my old computer that had all the weird 911s in it. Stuff like 20" wheels and other oddities.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Interesting! Yeah i feel like 9" wide front and 9" wide rear could look super cool.
I always liked the look of Randy Wells’ ST interpretation.
That would be an aggressive look. I wonder how well the wider wheels at the front would fit. Am running 930 wheels front and rear on my lowered SC and on some occasions the front tires rub the non-rolled fenders.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Behind the Sun
bottom of slippery slope
^ Thats one way to do it. There's also this car which came to mind and appears to be set up similarly to the white car above:
https://bringatrailer.com/listing/1973-porsche-911-2-5-st-modified/ |
What?
Me thinks the grip on the front would overcome the grip on the rear...especially with a tail happy car.
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
Uncertifiable!!!
This is a 930 16X9 rim on my current ST build. The rim edge is less than 1” from the strut and obviously the tire would not clear the rolled fender without a ridiculous amount of camber.
![]() ^16X9 ![]() ^16X9 This next pic is a 16X8. Man, this is tight especially with 930 shaved finned calipers.. ![]() ^16X8 My guess is that the 16X7 930 fronts will work best unless one wants to get into modified A-arms, etc. And BTW, Randy Wells’ gorgeous white ST appears to have 14”fronts and 15” rears. Just guessing.. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 08-19-2023 at 05:11 AM.. |
I am my 911's PO
Doesn't the 8x16 Fuchs from a 944 have better brake clearance than the 8x16 911 wheel due to different offset?
Uncertifiable!!!
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
911 16x8 is ET11 I believe
944 16x8 is ET23 I have 18x8.5 ET32 on the front of my car with massaged stock fenders. These small flare fronts that Carbone makes look nice. Looks like a 15x8 ET11 under them.
Uncertifiable!!!
^^^Evan, many thanks for the offset info. I’ll check my 8X16’s tonight.
Did you make any suspension mods like de-cambered ball joints to fit the 8.5’s other than the flares? That white longhood has an awesome stance with those 15’s. Thanks for sharing. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 08-20-2023 at 07:22 AM.. |
Fuchs from a 1986 951 (944 Turbo) have ET23,3 offset front/rear - exactly the same as 911 - but the center is moved outwards in the wheel (lugs are recessed) to make more room for the larger brake calipers (basic Brembos, IIRC) on the turbo cars. These wheels have their own 951 prefix part #'s. For 1987 MY onwards, all 944/951 were fitted with ABS, so use late offsets (ET52,3), same as the 964, 993 etc. There were no Fuchs made in ET52 at the time (although there are now, in 17") - so stock wheels for those cars were Phone Dials or Design 90s. Just FYI, Ruf Classics are 8J ET30.4 front and 9J ET17.7 rear. They fit G-body fine with no spacers needed for 225/45/17 and 255/40/17. In fact, the 9 looks so roomy in an SC flare, you might think you could fit a 10J under there. You can't, without Yellowbird flares or equiv metalwork....
'77 S with '78 930 power and a few other things. |
