Adjusting valves Just before TDC?
I noticed while adjusting my valves, that the most amount of slack I found was just before TDC and on the other cylinders just before the 120 degree mark rightfully.
If I continued onto TDC it tightens up a bit. I have a feeler gauge that I used and set them to on their rightful strokes. However if just before the stroke there is all this slack Im feeling, wouldn't that be a case for concern?
Old 08-30-2023, 02:10 PM
Following
Old 08-30-2023, 02:20 PM
Wellinginc1,
You should watch a YouTube video on how to do this:
https://www.youtube.com/watch?v=DQI9OR0Vt4w
If the engine is in the correct position for valve adjustment, rotating the engine several degrees should not make any difference. The cam lobe should be on the "base circle" during valve adjustment.
https://www.google.com/url?sa=i&url=https%3A%2F%2Fegnation.com%2F2016%2F11%2F21%2F all-about-that-base-circle%2F&psig=AOvVaw1aE1t91tq8LYFt-iISzzu3&ust=1693523278535000&source=images&cd=vfe&opi=89978449&ved=0CA8QjRxqFwoTCJjkx_-_hYEDFQAAAAAdAAAAABAE
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 08-30-2023, 03:02 PM
Correct Stroke………
Are you sure you are doing the valve lash adjustment at the right stroke (Z1 compression)?
Tony
Old 08-30-2023, 03:30 PM
sounds like you r in valve overlap for the cyl u r adjusting.
not compression stroke
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 08-30-2023, 07:15 PM
