Which Carrera 3.2 has 6,600 redline?
I was chatting with a 3.2 owner yesterday - standard body, not supersport, and with a whale tail - I asked why his rev counter redline started at 6,600 not 6,400. He knew nothing about it, except he'd had the car fron almost new, so he was certain the rev counter had never been changed and it was as it came from the factory.
It was G50, and what he did say was, it was one of the very last ones produced - maybe this accounted for the higher redline? Can anybody account for this? I wondered if it was possibly a factory uprated engine or maybe a clubsport (I noticed no other graphics) as I heard those have uprated internals? |
Been here a while
Clubsport and turbos had higher redlines
looking for 1972 911t motor XR584, S/N 6121622 |
turbo does have a 7K+200/-100 revlimit compared to n/a 6520+/50 but the peak hp is @400rpm less
Even the "usual suspects" bolt-on upgrades to add 100-150HP don't move peak power over 6K; Ultimate 930 Dyno Thread!
'77 S with '78 930 power and a few other things. |
That graph certainly looks to peak right at 5500 RPM, the engine speed the factory quote max HP at for both the 3.0 and 3.3 turbos, in both the FSM and (for the 930/60) - what looks to be the same bulletin page the posted graph came from:
![]() (entirely as expected; SC cams move the power band up a fraction - but still peak where they do on an SC - between 5500 (1978 SC) or 5900 RPM (1981 SC). You need more radical cams than that - and a laundry list of complementary mods - to get HP peak over 6K). The FSM also quotes "max permissible speed" (don't rely on the rev limiter if you still have the string cheese rod bolts) and "max constant speed":
Not sure what your point is
here are the specs for all of the `1984 versions ![]() and here all for 1981
Diss Member
Steve Wong went in depth in this post: https://forums.pelicanparts.com/porsche-911-technical-forum/94890-u-s-carrera-clubsport-demystified-dme-chip-analysis.html
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
