Administrator
Home Made Corner Scales
This is a project I've got $110 in, so far. I think it's probably more accurate than the typical grassroots 'Ruggles' approach of using a single bathroom scale with a lever cradle to reduce the force on the scale by a factor of four. I just bought sixteen scales at Ikea -- at $5.99 a pop. I was able to test for accuracy by, well, standing on each one. They were all within a pound, and with this kind of redundancy, the 'noise' of the scales' inaccuracies can cancel each other out, somewhat.
![]() ![]() My first attempt used a cut up 4x4 and only 10 scales. When the car fell off the 4x4, I decided another approach was in order. So out came the welder and a rusty old piece of 1x1x1/8" tubing. ![]() Testing: ![]() Once I got all four corners level and at the same height, I got easily-repeatable results. Thinking I had a full tank, I got 2,404 pounds. Then I took the car out and learned I was 2.5 gallons under a full tank. After topping off, I got 2,421 pounds. This is within a fraction of one percent of the Hergesheimers scales. Corner weights check out pretty well, too. ![]() Granted, it's kind of a pain in the butt. And if you didn't have a lift, it would be even more time consuming. But it seems to work.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Fleabit peanut monkey
RETIRED
I would suggest rollers.....that way you can flatten out the suspension after an adjsutment.
Rollers like on a dyno or at the DMV test facility?
AutoBahned
Jack - you have a serious problem.
1980SCMan
well done, Jack!
i've seen people try this and fail. but little more push and creativity like you did, i learn it is possible.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Administrator
I can't argue with that.
![]() I'm glad no one was watching. After the first weighing, I realized the trunk was still packed with all of my track stuff. So I took everything out, but then -- after weighing the car again -- I decided to weigh all of the stuff I'd taken out to see if my numbers were holding up. That meant standing with a bathroom scale six or seven times in a row, each time holding some of the stuff from the trunk, checking off a list and writing down the net weight. Kind of nuts. (But the numbers matched!)
air+fuel+spark
Love it! Thanks for sharing Jack! ...back to grinding =)
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle R Gruppe #653 |
durn for'ner
Brilliant!
Of course that will only work with Swedish bathroom scales.
Markus Resident Fluffer Carrera '85 |
Where do you keep all these gizmos Jack?
Good plan , well thought out.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Jack, we don't know each other but I have been following your adventures here for some time. I finally have to ask:
Were there any mad scientists in your family? I love the ingenuity! It is inspiring watching your antics :-)
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I am lucky to have a friend that owns a set of real scales that I can borrow. He has a neat home made set of rollers. He uses large ball bearings placed into divots on a bar of steel. It takes a while to set up but it works to allow the suspension to settle.
He found the problem was when he lowered the car down the suspension does not go straight up, it is at an angle. It would tear up the scales. With the bearings and two pieces of steel on each wheel it could wiggle around as needed. Your solution is as usual simple.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Ikea is going to wonder about the global run on bathroom scales
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
Under the radar
Jack Olsen for president.
Location: behind the redwood curtain, (humboldt county) california
Verification
Hi Jack,
Being a contractor, i occasionally come across buildings and slabs that are occasionally out of plumb, level or square, so, as i was admiring your home run, (simplicity and low cost), i was considering the possibility that your floor might not be dead flat. Then, how to test for that. On my second beer, i had a thought, just turn the car around on the scales and see if you can get real close to duplicating your prior readings. Here is a shot of my attempts to get a flat surface to install borrowed scales and give the car a bit of room to roll back and forth to get rid of "stiction", occurring after lowering the car back on the scales after making an adjustment. A bit heavy but fun to drive. Looking forward to getting Dad's 74 squared away. Regards, chris
Take a look what the kart racers are using. Seems to me you could easily fab up something like this but make it a little more stout.
KART RACING PRODUCTS - SCALES & STANDS - Leather Neck Scale Fixture Kart Scale Levelers & Racks Intercomp Racing I've seen intercomp PT300 scales at DoD DRMO sales for around 150 a set. I think they are rated at 10K Not sure how easily they could be adapted to use as race scales. |
best thing about IKEA are the names of the products..what are those scales called?
the "Svågertorp"? jack, is your garage floor level?
poof! gone |
Administrator
![]() Quote:
This is awesome I run micro sprints and can't afford actual scales but need some so I might have to try this great job jack
