Uncertifiable!!!
Banana Arm Bushing Issue
I'm Resto-modding a '71T and am attempting to install new URO Brand trailing arm bushings sourced from our host. Trailing arm insert cavity measures a diameter of 30.84 mm whereas the bushing measures 34.27 mm frozen just out of the freezer (24 hours).
![]() ![]() ![]() Cleaned out the cavity, rounded the edges, and lubricated but the bushing still does not even start to settle in straight with a press. Tried filing the leading edges of the bushing and trailing arm but still not success. ![]() In desperation, I ground some cuts into the bushing but still no joy. ![]() So, is this really a trailing arm from a '71T ? There are no markings or part number, which I find odd. ![]() I note that our host also sells some Polygraphite bushings that may do the trick. Anybody have any experience with them? Any suggestions and observations would be really welcome. Thanks in advance. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 10-04-2023 at 03:47 PM.. |
Elephant has a really good product
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Hi Johan, from what I can see in the pictures, it looks like you just might have the steel sleeves from the original bushings still in the trailing arms. You might be able to beck with a magnet. Those sleeves if indeed still installed should be removed before the new bushings will fit.
Best of luck, Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
As others noted, the outer bushing press fit sleeves are still in the arm. Note the parting line / split.
https://m.youtube.com/watch?v=4bilewM7Zsw&t=6s%3Fiframe%3Dtrue&width=80%25&height=95%25 |
The 9 Store
Elephant sells a tool to remove the bushings but you can (carefully) use a drift.
All used parts sold as is. |
Uncertifiable!!!
Many, many thanks to all of you for your quick responses.
Man, oh man, am I embarrassed! I am humbled by the wealth of knowledge that fellow Pelican are willing to eagerly share and take the time to respond so quickly. I will now sleep well tonight. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 10-04-2023 at 06:56 PM.. |
Steel sleeves are still in, happened to me too! Like said previously the ER tool is a savior for this project... I bought mine, took a total of 4 wacks at it and sold it for a $20 discount in the FS section within 45min of posting it.
Tool can be found here: https://www.pelicanparts.com/More_Info/ER2020903.htm?pn=ER-2020903&bc=c&SVSVSI=0590 -Ian |
Banned
Hopefully goes without saying but you're going to need to buy a new bushing, yours is now toast with those modifications.
I used the elephant tool it works great
Uncertifiable!!!
Cheers to everybody who chimed in to help. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
On another note, I would not use URO on my own car if you paid me to
1976 911 1976 914 1986 951 |
Banned
There's lots of stuff I'd use URO for, but not for suspension bushings.
Uncertifiable!!!
Thank you both for your suggestion. Out of interest I went back to my photo album for my RST build and I note that I used polygraphite bushings. Photo is dated July 31, 2015 and the RST now has probably in excess of 50k km since it hit the road a year later. The suspension is still very quiet but nevertheless I will check them out this winter.
![]() Cheers, Johan
