Still Doin Time
The early DME's to @"85 was 2K board processing speed. There is a jumper on the board where you can double that to 4K. The late 88 to early 89' went to 8k but the chip pins are different than the earlier ones. The difference is how quickly the engine management adjusts to a modified engine.IE: Quicker revs, flicking throttle. My experience is the 915 trans will handle more HP/TQ than 300+, but not a lot more. The rest of the car will absolutely handle more as it is so well balanced
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Grappler
Thanks! @ Bickyd. I'm running a Precision SC6162 that I purchased from a fellow Pelican back in 2011. It's still going strong!
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Cough. Probably because it's not correct.
From iscmhitz's post Permalink in this thread DME Update Questions: Quote:
This is not processing speed, it's setting the capacity of the chip that stores the maps and the Motronic firmware. Ditch the bloody Motronics already. It's freaking 80's tech - 40 years old. Less processing than your microwave or your toaster, much less your phone. It can't deal with anything "fancy" - much less anything that didn't exist in the 80's. It's like trying to hang on to CIS - why would you do that? And you need a piggy-back emulator to read/program a Motronic in real time (yes, they exist - a guy here builds them) - which almost any ECU built in the last 20 years or so just gives you out of the box. But this still doesn't let you drive boost control, variable cam timing, exhaust valves etc - or even datalogging.
'77 S with '78 930 power and a few other things. |
Grappler
I was looking at these once. https://www.vems.com/
Seems to be mostly plug and play. There's a Pelican "Raceboy" who was working with this company at one time. Not sure if he's still around, but he was quite knowledgeable.
