Mitch Leland's Avatar
1969-1973 split ring steering bushing
Our team has designed, manufactured and is presently road testing a MDS Nylon split ring steering bushing that we're told is a NLS item. I would like to get some feed back to see if there's a demand for this product. I'm not sure what the final production cost will be, however I'm guessing it will be less than $25.00, a lot depends on the demand, so that's a shot in the dark...
If there's a market for it then Pelican Parts will carry it as they do now for our "74"-"89" steering bushing, P/N PEL-ML-STR.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-01-2010, 04:31 PM
Wangrande's Avatar
Yes please!
72 T 3.2
Old 03-02-2010, 03:10 AM
Bandwidth AbUser
Jim Richards's Avatar
Yes!
Jim R.
Old 03-02-2010, 03:39 AM
goldsc78258's Avatar
Send a message via Yahoo to goldsc78258
I'll take 5 when they are ready
Old 03-02-2010, 04:18 AM
ratpiper71T's Avatar
i'll take 5 when they are ready
+1
Old 03-02-2010, 04:58 AM
E Sully's Avatar
Count me in.
Ed
1973.5 T
Old 03-02-2010, 05:44 AM
Looks to be a great item to reproduce, I would be in the market, sent my spare to s friend in the UK about 6 mo ago as he could not find one.
Regards
Old 03-02-2010, 06:03 AM
I appreciate the input, it looks like there's some interest. How about this... We have presently have one long term road test underway which so far has been successful. However I would like to do further road tests before putting the bushing into production. I would like to get 3 of you that drive your cars on a "regular basis" to try the bushing for further evaluation. The difference in my reproduction is the bushing is made of MDS Nylon which is a bearing material, but not steel as in the factory bushing. I want to be sure that the MDS Nylon will do the job...
I'll forward my split ring bushing, no charge if you'll report back in 30 days how it installed, and your overall opinion of it as a replacement part before I turn it over to Pelican Parts.
Mitch Leland
Old 03-02-2010, 07:07 AM
lin7310948's Avatar
ring!
does this necessitate that the steering mechanism be removed or is it like the later model bearings that just press {drive} into place or...am i just totally misguided about this part??
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 03-02-2010, 07:33 AM
The split ring bushing is under the steering wheel. Remove the steering wheel and the split ring bushing will be accessible.
Mitch Leland
Old 03-02-2010, 07:56 AM
GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
I have been working with Mitch L in getting this split ring to work as an Easy fix for the Early cars as there is one for the later model cars already.
I have personally had to replace the upper bearing because the split ring was missing which caused all the bearings to roll out of the upper bearing. Changing the upper bearing forces you to Remove the Entire column from the car to press the old bearing out... not to mention the cost of the OE bearing - not found aftermarket +$200.
I am still road testing the part with about 300-400 miles on the current configuration. The steering wheel feels Rock Solid.
Mitch L - Give me a call when you get a chance.
Old 03-03-2010, 08:36 PM
Yes Please!
Chris
Old 03-09-2010, 03:32 PM
Me too.
David Porter
Glyndon MD
'72 911T Targa
Old 03-09-2010, 05:04 PM
Hi Mitch,
i would like to purchase 3.. and can test them if you like...
Thanks,
Harry
porschesix2003@yahoo.com
626 379-7252 cell
Old 03-09-2010, 05:41 PM
Count me in. I do drive my '73 regularly just about daily. I will be happy to buy one.
Dick Lague
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-09-2010, 09:59 PM
Britain Smith's Avatar
Yes, I will take 1.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 03-09-2010, 11:26 PM
mitch
Put me down for two
I am happy to test in the 69 911 which is being daily driven at the moment
Michael
Old 03-10-2010, 02:02 AM
Carrerax's Avatar
Im also in for one!
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 03-10-2010, 09:46 AM
tobluforu's Avatar
I'm in, and will buy one now-don't care if it fails in a 6 months, a year or 5 as I do not put many miles on my car per year.
Old 03-10-2010, 10:11 AM
Split Ring Bushing...
Dick Lague
Dick,
I have one sample to put out for a road test. If you would like to try it, give me a PM with your e-mail address and mailing information and I'll forward the split ring bushing and steel washer to you.
Thanks,
Mitch Leland
Old 03-11-2010, 08:58 AM
