I have a 1973 Porsche 911 Targa that I am rebuilding. When I got the car it was in pretty rough shape. After sandblast and body work, it's finally looking like a car again.
My goal is to remove the stock front and rear bumpers. I am looking to use the RS or RSR front ant rear bumpers. My question is around the fender flares. I have been looking at adding metal fender flares that match up with the right bumpers. I am confused on the difference between RSR, RS and SC looks. I believe the RSR is the widest fender flare, 11" rear and 9" front I don't know the difference between RS and SC I DO NOT Want the super widebody RSR look. I want a wider look, but more subtle Can someone give me more info here. If you have done this before and have a good sight to purchase the flares and bumpers, please share
Jared 73 Porsche 911 Targa 57 Chevy 3100 |
The RS did not have flares on the front. RS and SC rear flares are the same width but have different shapes. There are threads with lots of pictures comparing RS to SC flares. Sent from my SM-G991U using Tapatalk |
wider than RSR 9 & 11 is '74RSR nominal 10 & 13 early RS, SC & Carrera are all nominal 7 & 9
Thanks guys. Got it on the RSR, 9 &11. That's a true wide body and probably more than I want.
I am looking at buying 73 RS bumpers front and back (From Getty Designs), My question is what size flares match up to this ? https://gettydesign.com/911tailbases/bumpers-and-splitters/
Does anyone know where to buy an 8" metal rear flares ?
For example: https://www.delawareporscheparts.com/oem-parts/porsche-insert-primed-91150360803grv?c=cT05MTEtNTAzLTYwOC0wMw%3D%3D
911-503-608-03
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
I have a pair of RS flares for $1000 if interested. Located in eastern PA.
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant. |
66 911 #302694
Jared,
I used SC flares and rolled the lips to take the flat edge out of them. I also grafted SC bumper extensions to the rear bumpers and rolled them as well (I had a set of 70 steel bumpers). Here are some pic's for reference. FYI this is on my 1966 911. The wheels are 9x16 Fuchs Also if interested I have a GT racing fiberglass rear RS bumper I didn't use. If your up for drive to the Berkshires I can give you a good deal on it. Joe ![]() ![]() ![]() ![]()
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim ..... WOW WHAT A RIDE!!!!!!! reaperwear |
I reshaped the stock SC front and rear fender lips on my '79 backdated hot rod.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
The early 2.7 Carreras and later 3.2 Carreras and SCs are all the same width, nominally 9" and accommodate up to a 9.5" wide wheel w/ the correct ET, So you can use any of the above quarter panels or weld on flares, be advised that w/ weld ons care needs to be taken w/ placement. I had no fitment issues w/ the f/g front RS bumper but there can be issues w/ any f/g part regarding fit and finish W/ 7 & 8 X15S ![]() ![]()
Have you considered ST flares? I used them on my car as I also wanted wider but not RSR wide. Mine are from gt racing. This is a crappy pic but it shows the flare pretty good.
78 911 st backdate 87 944 00 996 |
Thank you everyone. I think I am all set. Here is the plan
8" metal SC flares in the back. I found them on ebay and a few other sites No flares in the front RS fiberglass front and back bumpers Making my purchases tomorrow so I can get going.
