the car looks amazing. |
That means a lot coming from you sir. Now that it's close to being done I will say I hope to never go thru the process ever again. |
Tasty, I am looking thru my files for the before photos of the Classic Touring Seats "LeMans". Can't seem to find any with the headrest installed. I basically took the headrest foam and cut it down about 40%. Took a carving knife to it. If memory serves me correctly, I remember stuffing the cut down foam into the old vinyl cover and felt like I had reduced the overall size about 50%. http://forums.pelicanparts.com/uploa...1746827714.jpg ^ I don't know if this photo does them justice but these are how they are now. Recovered in new leather. |
Engine is in and running well.
The genius that is Ed Mayo did all of the tuning. http://forums.pelicanparts.com/uploa...1747751376.jpg http://forums.pelicanparts.com/uploa...1747751376.jpg Waiting on parts for the front brakes so that I can finish those up, put the tires on and drive it. |
It's now aligned and ride height is about where I want it to be. I still expect it to settle on the new suspension.
http://forums.pelicanparts.com/uploa...1749556958.jpg |
We are getting oh so close to that first drive report!!!
PS - Love the little parts logo on the fender. Nice touch!
Thank you Jonny, for everything. Yeah looks like rain here for a few days, I hate to complain when it rains in Texas in the summer. Got fresh hot air hoses (ducts) in from our host a few minutes ago. I'll get those on tonight. Just a few small things left. Waiting on: http://forums.pelicanparts.com/uploa...1749568707.JPG http://forums.pelicanparts.com/uploa...1749568707.JPG 15x7's on all four corners. |
First shakedown run this morning. About 80 miles. Mostly uneventful only a minor shifter adjustment needed. JWest was on site and happy to make the adjustment himself. Thank you sir.
http://forums.pelicanparts.com/uploa...1749926347.jpg |
Looks amazing!
Thank you tobluforu |
I can't get the video to load. ;)
Great work, Steve! |
Thank you Chris. I know you know what it took to get it to this point. Your insight and humor are always something to look forward to. I wish we could post videos here. I am going to try and get something up on you tube. This motor sounds pretty awesome.
http://forums.pelicanparts.com/uploa...1750679600.jpg
Final Detailing on the engine. Built and balanced 2.7 with S and RS parts. Magnesium Case (74) case split 4/9/24 Case vapor Blasted and Cerakoted. Machine work on the case by Soren Anderson. Pistons & Cylinders New Mahle flat top RS style. 90mm 9:1 Balanced Rods by Pauler Machine Crankshaft work by Armando - Custom Crank Shaft Head work by Pauler Machine New main bearings, rod bearings and intermediate shaft bearings Oil pump serviced for additional flow. Supertec head studs Supertec rocker arms Port match heads and new PMO Intake New modified S cams (Ed Mayo Spec) CSF oil cooler New PMO 40 Carbs (76mm) Turbo Valve Covers. Wevo engine mounts Engine assembled by Ed Mayo Results are a very angry motor that loves 7,000 rpms |
What brand/manufacturer is the front trunk carpet? Looks great.
trials935, That is one of the few things I did not make. I bought it from Carbone. When it arrived I did not like the edging so I removed that and had it rebound. I also did not like their logo emblem and pocket built into the portion that covers the area at the blower cover. So I removed them. This is what was left. |
Thanks, your 72 looks amazing. I sold my 72 I've owned for 36 years and was my dad's for 10 years before that and it was then in the process of being restored for 5 years. Here is after restoration. http://forums.pelicanparts.com/uploa...1750780998.jpg
trials935....beautiful car. Love the wheel finish and duck.
| All times are GMT -8. The time now is 08:12 AM. |
