Shimming Fixed Back (Bucket) Seat to Adjust Angle
Hi Pelicans:
I have a pair of BF Torino ST seats (fixed back buckets) in my 71T. The seats are great. Very lightweight. Well made. Great bolstering. They also seat me lower in the car so my head doesn’t hit the headliner. All great things. However, the recline of the bucket is a little much. I would like to make the seat back more upright. Based on my research, it seems like some have shimmed these (or similar) seats to address this issue. My question is: How is this best achieved—washers, spacers, something else? And how much should I be shimming—1/4”, 1/2”, more? Hoping the braintrust here can save me some trial and error. Thanks in advance. Last edited by Myami; 12-10-2023 at 09:54 PM.. |
I’ve gone through some extensive changes dialing in my seat position. I’ve lowered my seats 2 inches used steel spacers from ace hardware to dial in the seat back angle. I have found that experience 1/4’” will move the seat back angle 2 degrees. I think that for most, the best fixed seat back angle is found between 26-28 degrees.
I ended up with the pilot seat at 26 degrees and the navigator seat at 28. I purchased steel spacers at different heights at ace hardware. The seats I have are the classic touring RS seats with sliders.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Do you have any photos of the spacers, whether or not installed? Just trying to narrow it down and get it done right the first time. Our seats are different, but I would be curious to know the sizing you used on your respective seats as well, if it is not too much to ask. |
Spacers for 8mm seat mounting bolts.
![]() ![]() ![]() I removed the stock seat mounts. The new mounting points follow the same angle as the stock mounts they are just two inches lower. ![]() ![]() ![]()
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 12-12-2023 at 11:39 AM.. |
Banned
Is it safe to move the rails up off of the base like that? I would think in the case of an accident there won't be clamping force between the rails and base, and you'll be relying on the bolts alone, which will all be in single shear.
Yes, perfectly safe. Don’t make me do the math but it’s a schittton of force to rip through a 8mm bolt and it’s going to take more than 150 mph head on slam to break four of them free. And I wear my seat belt and all my mattresses still have the tags, so I’m good.
Banned
Banned
I mean the answer is "you're probably right", but if it's my butt in the seat I wanna see those formulas!
It goes without saying that to reduce the recline (my upper back doesn’t make total contact with the upper portion of the back rest), I need to add spacers to the rearmost two bolts. Correct? Last edited by Myami; 12-13-2023 at 03:29 PM.. |
