help with name of this part please?
engine right side behind airbox/oil filler, 2 hoses one down behind engine shroud, the other out thru inner fender wall routes under car to somwhere in front. This latter hose is in piece and I can see where it starts but not where it should end, what is it for and what is it called so I can replace (assuming the factory engineers had a good reason for putting it there )
thank you!
_______________________
'85 Black ROW Coupe (trying to put back together)
'88 Blue 951 (sold)
'84 Blue couple (sold)
Old 12-11-2023, 12:49 PM
Need a context photo, can’t tell where this is.
Old 12-11-2023, 01:38 PM
I haven’t owned a 3.2 in 20+ years, but that sounds/looks like a vacuum canister to me.
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 12-11-2023, 01:48 PM
Look under the fender for the charcoal cannister.
206 637 4071
Old 12-11-2023, 06:12 PM
someone else posted same question same day it seems and I got my answer the hose from the charcoal goes to the gas tank as suspected! No clue how I will install that but here's too trying!
https://forums.pelicanparts.com/porsche-911-technical-forum/1151975-vacuum-hose-connected-thermo-valve.html#post12149699
'88 Blue 951 (sold)
Old 12-13-2023, 04:28 PM
