Does anyone make a complete kit to backdate heat on an '83 911SC?
I'm looking to back date the heat on my '83 SC to earlier style. I will be doing SSI's shortly after.
Does anyone make a comprehensive kit of everything needed to do the conversion?
I have been doing some research and it looks like I will need left and right ducts to the sides of the fan, additional hoses, and apparently certain parts of the engine tray need to be replaced?
I see FVD has a kit, but it says it is for a 3.2 car. https://www.fvd.net/us-en/FVD211328490/heating-retrofit-kit-911-32-l-early-style-1974-dual-in-muffler-dual-out-header-exchangers.html
Will that work for me? I am trying to do it as clean as possible using factory parts. If a kit doesnt exist for an SC, could someone post the list of individual part numbers to do it?
Thank you!
Old 05-18-2022, 12:00 PM
There is no earlier style after the 74 model year
Go directly to SSI.
All you can do with the 83 is a cat replacement and maybe a noisy muffler
Bruce
Old 05-18-2022, 12:50 PM
Matthew_VA's Avatar
I did a heat backdate on my '83 targa a few months ago. All you need are the following:
LFT & RHT Heat Ducts
https://www.pelicanparts.com/More_Info/93010632101V2PH.htm?pn=930-106-321-01-V2-PH&gclid=Cj0KCQjwspKUBhCvARIsAB2IYuvy5hLFAmSX1sQjethI ZAPjXPHbvhjBOge0gTxUN0vn3DwWmaBFf3saAmx4EALw_wcB
https://www.pelicanparts.com/More_Info/91110632201PH.htm?pn=911-106-322-01-PH
and 4 feet of CAT-10 DUCTING 2 1/2"
https://www.aircraftspruce.com/catalog/appages/cat.php
Very straight forward install, no need to replace or modify engine tray.
TBD
Prior: '84 911 3.2 Carrera, '83 911SC Targa
IG: @heuersandcarreras
"I want to use it. That's what 911s are for." - Richard Hammond
Old 05-18-2022, 01:25 PM
For my '81, I used just the left and right fan shroud plates. The ducting went through the factory holes in the engine tray and connected to my factory heat exchangers.
911-106-322-01-PH Right Side Heater Duct
930-106-321-01-V2-PH Left Side Heater Duct
Old 05-18-2022, 01:28 PM
RETIRED
Joe Bob's Avatar
You can do an SSI with a dual in, single out muffler. Be advised not smog legal in many states
2012 ML350 3.0 Turbo Diesel
Enginerd
TxGerman's Avatar
Thanks TurboTim14 for asking this question. I have been wondering this as well and had started to collect the parts required. Thank you Matthew_VA for providing the information.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 05-18-2022, 01:33 PM
Thanks all for the pics, links, and part numbers.
Instead of buying the Cat-10 hose, can you use the stock hoses that run down to the heat exchangers to attach to the new L & R shrouds? Or is the tubing diameter different than stock?
Old 05-18-2022, 01:49 PM
Matthew_VA's Avatar
I believe I initially tried the stock hoses but the one on the right split/ripped so I pulled it and used the CAT-10...
TBD
Old 05-18-2022, 02:22 PM
I did an 83 this last year. Very straight forward once you have the pieces in hand. The fit on the block off tins needed some massaging but over all a worthwhile mod imo.
Old 05-18-2022, 03:53 PM
Bill Douglas's Avatar
Thanks Matthew. I'm thinking of doing it on my SC.
Old 05-18-2022, 09:21 PM
RETIRED
Joe Bob's Avatar
Make sure you don't snap any exhaust studs.....buncha threads on the subject.
Old 05-19-2022, 02:47 PM
jungspike's Avatar
Thanks Mattthew_VA for the links--very helpful.
84 911 Targa 3.4L
Old 01-14-2024, 07:33 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
Aircraft Spruce is your source for (non-paper!) ducting.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 01-19-2024, 06:57 PM
its so easy Pelican has the 2 parts and the ducting you can get on amazon. Not sure why you'd be worried about snapping anything it's literally like 6 screws and you're done.
Heat is way better than the factory on my 83 now. And so much room to move, no clue why I didn't do this earlier...
Old 01-20-2024, 10:19 AM
