86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Shifter adjustment 86 911.
The shifter on our 911 is very loose/rattle around 2200-2800 rpm’s in 3rd gear.
All other gears are fine&tight.
The coupler is new, and I’m advised that the
bushings are not worn.
Tried several mechanics, but no joy.
Any thoughts from the pros out there.
Thanks in advance, and best of TG holiday to all.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-08-2023, 11:51 AM
gtc gtc is offline
abides.
gtc's Avatar
Do you have the factory shifter?
I'd remove the boot and see if you can tell where the rattle or slop is coming from. In my experience, the pin at the front of the shift housing (secured by the large locknut) is a common culprit.
The shifter can usually benefit from cleaning and relubing everything (then you can also see what pieces might be worn.)
Graham
1984 Carrera Targa
Old 11-08-2023, 02:55 PM
Schulisco's Avatar
From where is the rattle noise coming? Shifter lever or linkage or from the gearbox itself?
Could you make a record / video that we can hear/see what you mean?
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 11-09-2023, 01:43 AM
I'll bet money your Shift linkage bushings are worn/blown. Experienced the same issue, and after installing a new linkage assembly the problem was resolved.
Old 11-09-2023, 02:06 AM
Cevan's Avatar
I just fixed this same issue
Rattling shifter.
1986 Carrera coupe - black on black
1972 CB500/4
Old 11-09-2023, 03:17 AM
Rattling shifter.
Just as i suspected, rotted bushings
Old 11-09-2023, 04:04 AM
