1983 sc. RF turn signal won't blink. What am I missing?
I'm sure this is a stupid question, but I can't figure it out. The right front turn signal on my '83 sc doesn't work. The parking light works. All of the other turn signals work (including right rear). I've replaced the light assembly, the bulb and the relay. I used a test light and there is no flash. What's left?
Old 11-10-2023, 06:03 AM
Maybe a dumb suggestion but I did it before. Check your fuses, the front L/R blinkers have their own fuses.
Edit: I mean that the blinker fuse is independent of the parking light fuse.
1982 911SC
Old 11-10-2023, 06:10 AM
Good call on the fuse. I will check it. But the left front works (for both turn signal and hazard) it's only the right front that doesn't.
Old 11-10-2023, 06:33 AM
Yep. The front left and right flashers each have their own fuse, which is separate from the fuse for the parking lights at each bulb. It's kind of overkill but there you go.
There's a circuit diagram in this thread:
https://forums.pelicanparts.com/porsche-911-technical-forum/906743-blinkers-not-working.html
1982 911SC
Old 11-10-2023, 06:57 AM
Well I'll be dipped! That was it. Thank you!!
Old 11-10-2023, 07:27 AM
theiceman's Avatar
now go find out why the fuse blew
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-10-2023, 07:49 AM
The usual answer is "****'s old".
1982 911SC
Old 11-10-2023, 08:05 AM
